Cel 16 Fuel Injector
I started me car up this morning from sitting overnight and it was running like crap, then throws CEL 16. I look it up and it says its code 16 which is Fuel Injector. I check all the plugs on the injectors and the last one is broke but its still on there does it still need replaced? I also measured the ohms between all the injectors and they all read 12 ohms. Another thing I notice is the smell of a gas like a lot so I'm guessing its not completing the combustion process? Fault with an ignition component? Has new wires cap and rotor.
Where is the main relay? another thing is its getting spark and gas i changed out the injectors same problem cause the car will start and run i pull the spark plug off number 4 piston and it just runs the same
jdmek2277
10
Nov 18, 2007 04:34 AM
