Is this ECU ok?
Old Aug 24, 2008 | 08:28 AM
dsmh8tr's Avatar
Default Is this ECU ok?
i have a jdm b18c with a 99 SI ecu. it runs fine and everything but was just wondering if a GSR ecu would be better as far as VTEC x-over and just in general. i heard it's not good to have an ecu that was made for a 1.6L to run a 1.8L motor not not sure if it's true. thanks for the help and any info.
Old Aug 25, 2008 | 08:04 PM
dsmh8tr's Avatar
Default Re: Is this ECU ok? (dsmh8tr)
anybody?
Old Aug 25, 2008 | 09:16 PM
mtber's Avatar
A gsr ecu would be ideal. The fuel maps, ignition timing, vtec engagement point is different on a b16 then it would be on a gsr.
The ideal solution would be a chipped obd1 vtec ecu with an obd2 to obd1 jumper harness
Old Aug 26, 2008 | 04:59 AM
dsmh8tr's Avatar
Default Re: Is this ECU ok? (mtber)
thanks so much. i will look into the chipped obd1 vtec ecu with an obd2 to obd1 jumper harness. what is the advantage of doing it this way. i will be searching like a mad man.
Old Aug 26, 2008 | 08:46 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsmh8tr &raquo;</TD></TR><TR><TD CLASS="quote">thanks so much. i will look into the chipped obd1 vtec ecu with an obd2 to obd1 jumper harness. what is the advantage of doing it this way. i will be searching like a mad man.</TD></TR></TABLE>
More tuning options for OBD1
Old Aug 26, 2008 | 10:00 AM
Relic1's Avatar
which JDM B18C do you have? the GSR version or the ITR version?
Old Aug 26, 2008 | 08:13 PM
dsmh8tr's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">which JDM B18C do you have? the GSR version or the ITR version?</TD></TR></TABLE>
the GSR version
Old Aug 27, 2008 | 07:40 AM
Relic1's Avatar
then for sure the P72 would be much better.
Unless you've changed the intake manifold.
Old Aug 27, 2008 | 07:13 PM
dsmh8tr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">then for sure the P72 would be much better.
Unless you've changed the intake manifold.</TD></TR></TABLE>
yeah, i have a skunk 2 IM. how does that make a difference.
hondatuner020
Engine Management and Tuning
Mar 4, 2010 03:50 PM
Neptronix
12
Jan 25, 2008 08:06 AM
2.2 teg
Oct 20, 2005 08:21 AM
Project92Hatch
Apr 17, 2003 10:52 AM
