new cams, won't start
Old Aug 24, 2008 | 06:15 AM
10kEG's Avatar
Default new cams, won't start
I have an '01 GSR, i just installed new cams and now it won't start. and when it does start it acts like it has a big miss. Valve lash has been adjusted, intake-.007(.17) exhaust-.008(.19). Timing has been checked about 10times so it is correct. It also has new wires, and the plugs are still in very good condition. PLEASE HELP!!
Old Aug 24, 2008 | 07:29 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: new cams, won't start (10kEG)
Did you use the red mark to find TDC? Check the cam timing.
Old Aug 24, 2008 | 07:31 AM
LSracing94's Avatar
Default Re: new cams, won't start (Dogginator)
how are u checking the timing? sound off to me
Old Aug 24, 2008 | 08:23 AM
10kEG's Avatar
I used the white line on the crank pulley. the red line is used for ignition timing. The cam gears are up with lines matching. I thought that the cams may be 180 out but that wasn't it. I'm pretty stumped right now...
Old Aug 24, 2008 | 08:42 AM
10kEG's Avatar
Would a tiny bit of slack cause it? wen we put it in time all the lines match up, but after trying to start it the white line on the crank pulley looks to be off by about one tooth.
Old Aug 24, 2008 | 09:19 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (10kEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10kEG &raquo;</TD></TR><TR><TD CLASS="quote">Would a tiny bit of slack cause it? wen we put it in time all the lines match up, but after trying to start it the white line on the crank pulley looks to be off by about one tooth.</TD></TR></TABLE>
I always check the cam timing before and after tensioning the timing belt.
Old Aug 24, 2008 | 11:58 AM
10kEG's Avatar
Part of the problem seems to be the valve lash was a hair off, re-adjusting now
shesinmyroom
11
Jun 7, 2012 08:07 PM
APEX CRX
Sep 19, 2006 10:59 PM
teamredline9k
May 29, 2006 06:12 PM
