97 civic ex coupe check ebgine light is on need some help
Old Aug 23, 2008 | 06:06 PM
irishbobby23's Avatar
Default 97 civic ex coupe check engine light is on need some help
code 9=cylinder sensor where is this sensor located is it the dizzy,also code 74 misfire on cylinder#4 spark plugs r new,wires are new,injectors are new,am i missing something wit this code i need some help thanks alot guys
Old Aug 24, 2008 | 02:27 AM
boostedhks's Avatar
I am no expert and i am not sure, but man i think that ur piston #4 is about to pass away... re-check with sum1 else but if u think about it all the check engines are about a piston, and code 74 specifies that is piston 4 we're talking about.
Old Aug 24, 2008 | 03:59 AM
Default Re: (boostedhks)
thank you,my friend works for honda he is a A tech he said the cylinder sensor would b making that code come on,also he said the sensor is behind the timming belt cover does anybody no if this is true?
kaivorth
May 27, 2014 02:15 PM
qazaq
Sep 29, 2006 07:47 AM
andee75
Jul 1, 2004 11:46 PM
