VSS??
anyone know exactly where the speed sensor is on a 92 si hatch with a Z6 its all stock. my speedo loves to jump around since i bought it. it works more often then not but its still bother me im thinking a loose connection at the VSS but idk where it is exactly, is it in the same spot as a B-series tranny??
Hey just to let you know I would suspect the Speedo cluster. I have a 92 hatch and I've had 3 different clusters in it. The first one the tach didn't work all the time, the second one the speedometer worked intermittently, and the third one everything works fine. I also had a 93 4-door that the speedo worked intermittently on, and replacing the cluster cured it.
mayfly
15
Jan 21, 2012 08:55 AM
