Type S in the Prelude sh
Old Aug 23, 2008 | 09:23 AM
bb62o3's Avatar
Default Type S in the Prelude sh
I jus bought a type s complete motor bout to put it in the sh. Is there any problems i will run into? Is everything going to be plug and play and run properly?
Old Aug 23, 2008 | 11:33 PM
Kronn 98SH's Avatar
Default Re: Type S in the Prelude sh (bb62o3)
Type S is OBDI, I believe. Did you get the Type S ecu along with the motor?
Old Aug 24, 2008 | 06:26 AM
92hondalude's Avatar
you will need a intermediate shaft if you dont have one already
Old Aug 24, 2008 | 06:55 AM
vinuneuro's Avatar
Default Re: Type S in the Prelude sh (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">you will need a intermediate shaft if you dont have one already</TD></TR></TABLE>
The Type-S has ATTS like the SH.
Old Aug 24, 2008 | 08:28 AM
Default Re: Type S in the Prelude sh (vinuneuro)
woops sorry i forgot i feel newbish now
Thanks, i stand corrected
Old Aug 25, 2008 | 03:54 AM
RattyMcClelland's Avatar
The Type S uses OBD2 as it has ATTS. Should swap straight no problems.
Old Aug 25, 2008 | 03:56 AM
vinuneuro's Avatar
Default Re: Type S in the Prelude sh (RattyMcClelland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RattyMcClelland &raquo;</TD></TR><TR><TD CLASS="quote">The Type S uses OBD2 as it has ATTS. Should swap straight no problems.</TD></TR></TABLE>
Not true. People who have bought JDM Type-S swaps have reported that the ignition timing sensors are like the obd1 engines; ie. ckp/tdc sensors in the diz instead of at the oil pump. It's still nearly a straight swap, minus some minor rewiring that needs to be done.
Old Aug 25, 2008 | 02:00 PM
Iv just checked and apparently all JDm H22 use OBD1. So will my Type S with ATTS still use OBD1. If so this is good news. I can get even more power out of it.
Old Aug 25, 2008 | 03:16 PM
vinuneuro's Avatar
Default Re: (RattyMcClelland)
How do you figure that. The fact that the engine is obd1 or obd2 is arbitrary since you have to retain the stock ecu, whereas almost all the tuning systems require the use of p28, p72, etc.
Old Aug 25, 2008 | 05:40 PM
Revi's Avatar
Default Re: (vinuneuro)
When i did my Type-S swap the only "mod" i had to do was run the engine wire harness underneath the intake manifold in order to be able to connect it to the harness on the correct side. Other than that nothing else was done. Just make sure you use the JDM Type-S ECU and youll be fine.
Old Aug 25, 2008 | 05:54 PM
vinuneuro's Avatar
Default Re: (Revi)
So are the crank position sensors at the oil pump then? The fact that you didn't have to do anything at all means the engine is obd2 right?
Old Aug 26, 2008 | 05:46 AM
Revi's Avatar
The CPS is not at the oil pump and the distributor is internal coil. Also the VTEC solenoid has no oil pressure switch. Even thougth some sensors are located in different locations the wiring seems to lead to the same plugs on the harness. He just has to make sure to use the Type-S ECU. If he wants to use an external coil and a cps on the oil pump he is gonna have to use this OBDII harness.
Old Sep 5, 2008 | 10:51 AM
bb62o3's Avatar
Default Re: (Revi)
How did you "mod" the wire harness?? Jus got my motor TODAY!!! I see what your talkin bout. Let me Know how u did it
kingh90
Jul 6, 2008 01:11 PM
Bangher4$
Aug 27, 2006 06:59 PM
DC5AM
10
Jan 23, 2005 09:23 AM
TypeR15
Jan 29, 2004 06:50 AM
Dream
Aug 15, 2003 09:08 AM
