Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Motor rebuild... DIY?
Old Aug 22, 2008 | 05:42 PM
L8APX's Avatar
Default Motor rebuild... DIY?
So as i am getting more and more comfortable in my car, I am going faster, revving higher and spending more and more time in VTEC.
Unfortunately that also means I am using more oil.
I went to the track last Sunday. I drove there and back (140 miles) and 5 track sessions (4 25 minutes, 1 35 minutes). It's a pretty fast track so I am in VTEC for 90% of the time. I used 1 whole quart of AMSOIL. Just a few events ago I could go a whole weekend and only use 1 quart.
Anyway, I do actually have a point: next summer I want to freshen up the motor. is this something I can do myself (I'm pretty handy), or is it something I have to send the motor off to a shop for?
It's a B18C5 with sleeves and oversized pistons (2.0L), and a stage 4 DPR head. I was thinking new rings and valve stem seals, plus new crank and rod bearings ought to do it, no?
Just curious: what do you guys do for motor rebuilds? DIY or send to a shop?
Thanks
Old Aug 22, 2008 | 06:42 PM
bosco500's Avatar
Default Re: Motor rebuild... DIY? (L8APX)
Get yourself a factory service manual and read it. That will give you a good feel for weather or not you are able to rebuild the motor.
I would highly recommend doing it yourself. You will feel better about it and you will know its done right without shortcuts.
Old Aug 24, 2008 | 01:27 PM
L8APX's Avatar
^Thanks.
I'm guessing a part time effort over a month or two would suffice to get everything apart and back together.
I'll get my eyeballs on a service manual.
Old Aug 24, 2008 | 01:56 PM
Wendys or Bust's Avatar
What tracks are you racing at in Texas
Old Aug 24, 2008 | 02:24 PM
L8APX's Avatar
Only TWS at the moment. I'll likely try MSR Houston this fall/winter sometime.
Old Aug 25, 2008 | 09:10 AM
kommon_sense's Avatar
Default Re: (L8APX)
I sent my block to a shop for rebuild. I did the math to see how much it would cost to do it myself after I bought all of the necessary tools and such. I also thought about how often/little I would use the newly purchased tools (bore guage, ring filer, calipers, micrometers, stretch gauges, etc.).
In the end, it was only $200-300 more to have a professional do the rebuild, so I sent it out. However I did freshen up the head and rebuild the tranny myself. I only had the block rebuilt and did final motor assembly myself.
adrian1281
Jan 23, 2008 04:32 PM
Mike D
Apr 3, 2003 07:13 AM
PrecisionH23a
Aug 7, 2002 10:36 AM
alexboy
Apr 8, 2002 01:32 PM
