Breaking in a fresh motor...
Old Aug 6, 2002 | 09:02 PM
PrecisionH23a's Avatar
Default Breaking in a fresh motor...
First off, yes i used the search button already. Anyways, last summer i rebuilt my motor and when i broke it in i ran it N/A for 750 miles on non-synthetic motor not taking it above 3000rpms. After that, i installed the turbo, babied it for probably another 200 miles before really getting on it. Well i had my motor apart again, this time i went with new OEM rod and main bearings, new piston rings, headgasket, arp head studs, and the usual gaskets that need to be replaced and what not. This time i dont have time to run the motor N/A to break it in, so i will have the turbo installed. My question here is... Which oil should i use? I know when i run my turbo i run mobile 1 synthetic, but i know for break in periods this oil is too light. So what do you guys recommend that i do? Also, im going to have it dyno tuned soon, is 1500 mile enough mileage before having this done? I plan on having it boosting 18+psi... Thanks
Old Aug 6, 2002 | 09:56 PM
AGen2integra's Avatar
Default Re: Breaking in a fresh motor... (GudeH23a)
Yeah definately use a non synthetic for motoer break in. Use a 10w 30 motor oil for about 300 miles then make the change to synthetic.
Old Aug 6, 2002 | 10:03 PM
BoostinDC2's Avatar
Default Re: Breaking in a fresh motor... (AGen2integra)
i would run synthetic after about 1000-1500 but everyone has different opinions
Old Aug 7, 2002 | 12:26 AM
Gfunk176's Avatar
great question....i'm doing the same thing, built the bottom end and puttin in the turbo at the same time. how many miles should the break in time be and should i run at low boost first.
Old Aug 7, 2002 | 12:39 AM
VaporTrail's Avatar
New User
Default Re: Breaking in a fresh motor... (Gfunk176)
its not a question of boost, but more of a question of load and rpms. That should be your main concern.
Old Aug 7, 2002 | 01:17 AM
Xerxes's Avatar
New User
remove the spring on your wastegate so that it stays open all the time, that way you won't build any boost. And if you're not building any boost, then the turbo won't be spinning real fast and so it would probably be alright to use non-synthetic oil in the turbo.
-Xerxes
Old Aug 7, 2002 | 10:36 AM
Default Re: Breaking in a fresh motor... (Xerxes)
yea basically my concern was the non-synthetic oil running on my ball bearing turbo. I already had planned on doing the wastegate spring trick you mentioned, thanks for making sure ill be posting pictures soon...
EG-SIXV-TEC
Sep 2, 2014 02:22 AM
MOVE OVER
Jan 4, 2008 06:15 PM
ACrite3404
Jul 23, 2007 11:06 AM
lke2drvgsr
Sep 15, 2004 09:00 PM
crx1856
Sep 23, 2003 11:09 PM
