Civic EG wiring Dash Problem
Hi I need some advice please
I swapped my dash in my Civic EG from grey to black today and added some gauges ...
Everything works fine, ie car starts, hazards, sunroof and new guages
But the dash cluster..ie Revs, Speedo , turn signals and clock dont work
I had one blown fuse..7.5 amp in engine bay which i replaced..But still the same problem
I have either missed something, but aint to sure what..
i havent tried the radio/cd yet.. i guess that wont work either though
another thing with the car is, that when you put the key in , it makes that bleeping noise when door open, but same thing happens when cars started and door open ...never had that before until today...
Hope i can get some pointers etc...what to check etc
Thanks
Thanks
Also does anyone know where this plugs into?
Its a 2 pin plug, Grey
With a Grey/black wire and Brown wire, it gets aobut 4.5V with ignition on...
Its near the car stereo area, i cant seem to find anything to plug this too
Bit like the CEL service connector...
I checked all my fuses wiring, grounds...everything seems fine
Also voltages to cluster is fine...
But still my revs , my speedo my fuel, temp, oil pressure clock dont work
Only light which comes on the cluster is Battery light....
Its also making this annoying noise when door open" BLEEPING" even with car started... used to never do this...
Chris_Gee
12
Dec 18, 2021 07:57 PM
B18Cej1
Mar 30, 2004 08:42 PM
b16ferio
Feb 24, 2004 08:35 AM
