TPS problems
Old Aug 22, 2008 | 03:10 PM
86elco's Avatar
Default TPS problems
K car is a 99 civic with a h22 swap. When the swap was done back in january the shop that did it got a little rough with my throttle postion sensor and craked it slightly while putting the motor in, but it still worked fine. I've had a new TPS laying around for a while and finally decided to change it out today. Put it on turn the car on and bam, its now throwing a CEL for the TPS adjusted it some and unhooked the battery for a while and still throwing code 7. I tried putting the old one back on and still the same thing. car runs and idles fine, vtec still engages everything seems fine and i cant figure out why its throwing the damn CEL.
Anyone know what the problem might be???
Old Aug 22, 2008 | 03:32 PM
86elco's Avatar
Default Re: TPS problems (86elco)
Never mind found out what was wrong with it didn't have it set right.
Old Aug 22, 2008 | 03:36 PM
BryanM.'s Avatar
Resident Gearhead
It needs to be calibrated, I hope you did that.
Old Aug 22, 2008 | 04:54 PM
86elco's Avatar
Default Re: TPS problems (mcvtec)
yeah the volts were a little off,, got it straightned out when i actually barrowed a decent meter and quit using my junk one
MonKK
Jan 8, 2009 08:46 AM
tommyistommy
Jan 5, 2009 01:53 PM
irishpilot
May 8, 2007 04:14 PM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
COMplex.
Jul 17, 2003 05:51 PM
