Tire tech for stock wheels
Old Aug 22, 2008 | 11:42 AM
legomytego's Avatar
Default Tire tech for stock wheels
after spending some time searching and reading post from nsxtasxy i am just looking for whats been done and what you guys run i have just traded my jdm 16 inch wheels for the stock 15 inch wheels (thanks to those who were intrested ) i plan on running hankook R-s2 or falken azenis have driven on both auto x on the R-s2 i am looking for what size tire you guys have fit and what mods (fender camber ) the bigger the better my teg is turbo and can use all the help i can get thanks
example this guy is running a 225/?/15 what needs to been done to run a setup like that thanks in advance and sorry for my lack of Punctuation
Old Aug 22, 2008 | 11:49 AM
jgirard's Avatar
Default Re: Tire tech for stock wheels (legomytego)
15" Azenises only come in 205/50/15's, at least that's all I can find online....
Old Aug 22, 2008 | 11:51 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legomytego &raquo;</TD></TR><TR><TD CLASS="quote">
To run 225 up front you will need to run at least -3 camber and a slight fender roll. 205/50/15 Azenis will be fine.
Old Aug 22, 2008 | 11:58 AM
citrus3000psi's Avatar
I thought the 225 tires where to wide to run on the stock 15" rim.
If they arn't why aint I running them?
Old Aug 22, 2008 | 12:31 PM
get RIGHT's Avatar
Default Re: (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">I thought the 225 tires where to wide to run on the stock 15" rim.
If they arn't why aint I running them?</TD></TR></TABLE>
The national DS AutoXers do it all the time.
Old Aug 22, 2008 | 12:55 PM
HSPxNick's Avatar
Default Re: (get RIGHT)
What suspension you running on? how much are u lowered? , if you are lower, 45 - 50 series tire would be good imo. Depending how low you are, you might need to roll your fenders, maybe take off wheel wall if you don't want to rub, f&r camber kit..and/or get 40 series tires imo. 225 is good if is allowed at autox like the other guys said.
Old Aug 22, 2008 | 02:32 PM
ithrowpoop's Avatar
Default Re: (HSPxNick)
the wheels on that car are an old set of mine and are 205/50/15
Old Aug 22, 2008 | 02:42 PM
coolhandluke's Avatar
Default Re: (ithrowpoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ithrowpoop &raquo;</TD></TR><TR><TD CLASS="quote">the wheels on that car are an old set of mine and are 205/50/15</TD></TR></TABLE>
You confirmed what my eyeball was telling me. Poop FTW
Old Aug 22, 2008 | 07:24 PM
legomytego's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgirard &raquo;</TD></TR><TR><TD CLASS="quote">15" Azenises only come in 205/50/15's, at least that's all I can find online....</TD></TR></TABLE>
yea thats what i was going to go with if i just decided to stay 205 but the R-s2 come in a bunch of sizes for 15's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HSPxNick &raquo;</TD></TR><TR><TD CLASS="quote">What suspension you running on? how much are u lowered? , if you are lower, 45 - 50 series tire would be good imo. Depending how low you are, you might need to roll your fenders, maybe take off wheel wall if you don't want to rub, f&r camber kit..and/or get 40 series tires imo. 225 is good if is allowed at autox like the other guys said.</TD></TR></TABLE>
koni/ground control setup and i dont think more tire would hurt either thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolhandluke &raquo;</TD></TR><TR><TD CLASS="quote">
You confirmed what my eyeball was telling me. Poop FTW</TD></TR></TABLE>
the picture was taken out of the R wheels thread in a/c and sombody had listed that they were a 225 i am pretty sure ill try to find the thread
Old Aug 24, 2008 | 04:28 AM
legomytego's Avatar
dosent mugen mike or sombody run a 225 tire ? not sure what size rim but they are mugen wheels pretty sure
Old Aug 24, 2008 | 06:58 AM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legomytego &raquo;</TD></TR><TR><TD CLASS="quote"> sorry for my lack of Punctuation
Instead of apologizing at the end of your post, how about just using it.
Old Aug 24, 2008 | 07:01 AM
01_ITR's Avatar
Default Re: (legomytego)
This would be my car 3 years ago...
Old Aug 24, 2008 | 07:02 AM
01_ITR's Avatar
Default Re: (01_ITR)
you could pm previous owner of this car he might give you some idea of what he was running with this set up at that time.
Old Aug 24, 2008 | 07:11 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01_ITR &raquo;</TD></TR><TR><TD CLASS="quote">you could pm previous owner of this car he might give you some idea of what he was running with this set up at that time. </TD></TR></TABLE>
The owner has aleady spoken in this thread.
Old Aug 24, 2008 | 07:51 AM
01_ITR's Avatar
b18cjdmitr bought these wheels off of ithrowpoop. Didnt notice his post.
Old Aug 24, 2008 | 08:11 AM
Todd00's Avatar
I said I don't want a title!
If you're not running an R-compound tire (race tire, basically), then any street wider than a 205 will behave like crap on the OEM 15x6" wheels. R-comps have seriously stiff sidewalls that aloow them to work OK on skinny wheels. Street tires do not.
Actually, the wider 205 street tires are really too wide for a 6" wheel. They'll work, but handling will be extremely sloppy.
The best tire, right now, for the OEM wheel is the Dunlop Direzza Star-Spec 195/55/15. Anything else wider and you can forget about a car that transitions well or has good turn-in.
Old Aug 24, 2008 | 10:48 AM
legomytego's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">If you're not running an R-compound tire (race tire, basically), then any street wider than a 205 will behave like crap on the OEM 15x6" wheels. R-comps have seriously stiff sidewalls that aloow them to work OK on skinny wheels. Street tires do not.
well i will just stick with azenis unless i find a new set of rims thanks for all the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">
Instead of apologizing at the end of your post, how about just using it. </TD></TR></TABLE>
um maybe next time
Old Aug 24, 2008 | 12:26 PM
LudeEFv2.4's Avatar
My old title sucked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legomytego &raquo;</TD></TR><TR><TD CLASS="quote">dosent mugen mike or sombody run a 225 tire ? not sure what size rim but they are mugen wheels pretty sure </TD></TR></TABLE>
I believe his Mugens are 17's.
Old Aug 24, 2008 | 12:39 PM
get RIGHT's Avatar
Default Re: (LudeEFv2.4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.4 &raquo;</TD></TR><TR><TD CLASS="quote">
I believe his Mugens are 17's.</TD></TR></TABLE>
You mean 16x7?
Old Aug 24, 2008 | 02:34 PM
LudeEFv2.4's Avatar
You mean 16x7?</TD></TR></TABLE>
I may be wrong.
Old Aug 24, 2008 | 07:10 PM
nsxtasy's Avatar
H-T Order of Merit
Those using 225 treadwidth tires for autocross are using 225/45-15. And the stock 15x6 wheel size is too narrow for that size, which is approved only for wheels 7.0-8.5 inches wide.
I assume the competitive autocrossers are using the Hoosier A6 in that size.
If you're not going to get the Hoosier A6 (along with suitably wider wheels to use them on), then you may as well get the Dunlop Direzza Sport Z1 Star Spec in 195/55-15 for the stock wheels. It's faster than the Azenis in 205/50-15 (and way faster than the R-S2), and the Star Spec fits better on a 15x6. It's nicely priced at $86/tire at the Tire Rack, and right now you can get $40 off on a set of Hawk brake pads (or $80 off on two sets) when you buy a set of these tires. It's a great choice for a turbo car.
slammedNslowLS
Nov 27, 2006 04:23 PM
Nors
Jul 17, 2006 05:55 PM
buyer
13
Feb 6, 2006 05:33 PM
fastitr01
Mar 30, 2004 05:46 PM
stickyfingers
Mar 10, 2004 07:03 PM
