rsr exhaust rattles ??
I bought a 91 hatch and the exhaust rattled bad.. I got under it thinking it was the Cat but the sound was coming from a part of the pipe .. At first I thought a chunk of metal was inside. like a piece from the cat. Looked found nothing.. Frustrated i drilled the pipe to find it has another pipe inside.. (double layer exhaust?)
So I drilled like 25 holes just drilling the outer part and then got my welder and welded the inner pipe to the outer though each hole. Worked great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rex714 »</TD></TR><TR><TD CLASS="quote"> i can feel it hit the shifter
so do u know if theres a way go get a little longer bushing </TD></TR></TABLE>
Yes, go to a muffler shop or auto parts store and you will be able to find larger bushings for the exhaust hangers.
Do you have a short shifter? If you do changing back to a stock shifter might solve your problem also.gl
imadigitalgod
May 20, 2007 06:48 PM
AntF
Feb 13, 2006 01:42 PM
