Distortion on speakerwires?
Old Aug 22, 2008 | 01:51 AM
MrSnake's Avatar
Default Distortion on speakerwires?
I got me 4 new speakers, tweeters, amp and subwoofer installed (all Audio System) and it's working great, but ...
I've a constant soft-metallic ticking/hissing sound that goes with the rpm.
I got this as well when the audio system is turned off, it's as if some signal from the engine bay is picked up by the speakers or speakerwires?
Could this be from the amp? Which is in the trunk, but it has the power cable coming from the battery.
I got my power wires and speaker wires seperated.
The speakerwires are new and seemed shielded enough.
Do I need better wires still?
Or are there any other things that I could try?
thx,
Peter
Old Aug 22, 2008 | 04:38 AM
autoluder's Avatar
i had that problem in my first car, I was told it was because my rca's and power wire where ran on the same path.
Old Aug 22, 2008 | 04:53 AM
MrSnake's Avatar
Default Re: (autoluder)
thx, but I got the RCA cable together with the speaker wires on the rigth side.
The power wire is on the left side of the care.
Old Aug 22, 2008 | 09:40 AM
MilanoLude's Avatar
Default Re: (MrSnake)
Although it really shouldn't cause noise, do you have the remote turn on wire seperated from the RCA and speaker wires?
Make sure to check your grounds as well. Remove any paint from where the ground wire is attached and make sure it is securely fastened.
Are the RCA wires new and/or in good condition? If you remove them from the amplifier can you still hear the noise?
Old Aug 22, 2008 | 10:11 AM
MrSnake's Avatar
Default Re: (MilanoLude)
I got the remote-on wire on the same side as the power cable.
There are also signal cables. Not sure if that can be it, but there are signal cables on both sides.
The RCA wires are brand new out of the box. Weren't the cheapest either.
I haven't removed them from the amp yet, but I'll try that today. Thx.
barryboy1111
Jan 31, 2010 06:56 PM
K i l l a B e e.
Audio / Security / Video
Jul 15, 2008 10:12 PM
rockin_remz
May 27, 2006 07:30 PM
JDMlyfestyle
12
Dec 10, 2004 04:24 PM
95TEG
Oct 7, 2003 10:53 PM
