ive searched... please help
well i have two questions..
1. i just changed my clutch and flywheel and now my car pulls to the right. could it possibly be an axle? I hear clicking but only slightly( i can only hear it driving by center dividers on highways) and it is comming from the passanger side.
2. When im driving i can feel something clunking or bouncing? in my steering wheel and i have no idea what it is. i have ps removed and the lines looped with gear oil in there now. but for the first couple months i ran it un-looped and empty. could it be a rack and pinion?
please help this is so annoying, by the way it is a 1996 se.
unless you removed the tie rod end and changed the toe then your clutch and recent work has nothing to do with the car pulling i suggest you take it to a alignment shop.is your car slammed?lowered,stock height?the sound could be coming from a blown strut
You said you searched, but your thread title certainly won't help anyone else searching on this same subject. You really need to be more descriptive in your thread titles for this very reason.
Have you checked the condition of your CV axles since you put the transmission back on? Any torn boots? Any play in the joints?
I felt/heard a kind of creaking sound/feel in my steering wheel once, it was a bad lower ball joint (boot had torn and gunk had worn out the joint).
