video inside
Old Aug 21, 2008 | 08:44 AM
94dels0lsi's Avatar
Default video inside
[IMG]je 12;1 pistons stage 3 crower cam 440cc injector 68mm throtle body and spacer the car wont run by itself and when you push the gas evreything surges and dies its a d16z6 block with a y8 head please help
http://www.youtube.com/watch?v=p9O3LFehRps
Old Aug 21, 2008 | 08:49 AM
Hanmin's Avatar
tps and map switched? is your tps calibrated???
Old Aug 21, 2008 | 08:54 AM
94dels0lsi's Avatar
there not switched but it is not calibrated would it make that much of a diffrence i have a adjustible cam pulley i moved it a few times and it didnt seem to help at all
Old Aug 21, 2008 | 08:56 AM
Hanmin's Avatar
try taking it out for a spin, cars act differently under load. any cels? I dont know where the cel light is at on a del sol cluster...
Old Aug 21, 2008 | 08:59 AM
94dels0lsi's Avatar
i tryed to drive it and it chokes and bogges out i couldnt really tell but it looked like there was a little bit of white smoke then by the time i finally got it in my drive way it shut off and wouldnt restart for a little while
no cels
Old Aug 21, 2008 | 09:14 AM
Hanmin's Avatar
it cant go passed a certain rpm when your driving it? try calibrating your tps, It can cause your car to bog out. try that then come back. And when it dies out, are you trying to give it gas??? you probably flooded your cylinders, thats probably why it doesnt start right back up.
Old Aug 21, 2008 | 11:16 AM
obuhmyuh's Avatar
Default Re: (Hanmin)
timing? possible ignition or cam timing off.
Old Aug 21, 2008 | 12:03 PM
sageuvagony's Avatar
Default Re: (obuhmyuh)
My car acted just like that when my timing was off a tooth or 2.
B17SolRide
14
Oct 23, 2014 07:04 AM
Eddie 70
Jan 23, 2014 02:03 AM
94dels0lsi
Aug 21, 2008 04:50 PM
97ekcoupe_pa
10
Jan 21, 2008 05:19 PM
b18c5 EG
Jun 11, 2005 07:56 AM
