81m JE pistons
Old Aug 21, 2008 | 12:23 AM
dc2_916's Avatar
Default 81m JE pistons
is it okay to use the 81m JE pistons for a all motor gsr . would the piston make the car get higher compression or lower.its oversized pistons also
Old Sep 14, 2008 | 07:38 AM
birdman91089's Avatar
it all depens on the compression rating for the piston
Old Sep 14, 2008 | 08:21 AM
fcfromhell420's Avatar
Default Re: (birdman91089)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birdman91089 &raquo;</TD></TR><TR><TD CLASS="quote">it all depens on the compression rating for the piston</TD></TR></TABLE>
x2
what do you mean its oversized?
Old Sep 14, 2008 | 08:32 AM
bigger than 81 mm
Old Sep 14, 2008 | 10:23 AM
ls19integra95's Avatar
81mm is oem size on my ls... so hows it larger for gsr? also if its larger then youd have to get the motor either bored or honed slightly and also look at what the compression ratio is on the piston, there are flat top, dome top, and inverted dome top pistons, and they each have different compressions...
team 15
Jun 22, 2007 03:49 AM
ochsy03
Mar 12, 2005 08:33 PM
Si Integra
Feb 11, 2004 02:29 PM
Teal95Coupe
Aug 17, 2003 05:12 PM
greengangsta
Mar 18, 2002 07:23 PM
