1994 Honda Accord fan (blower) - heater/ac
Old Aug 20, 2008 | 05:38 PM
nramil's Avatar
Default 1994 Honda Accord fan (blower) - heater/ac
I have a 1994 Honda Accord LX. The interior heater/ac fan (blower) only turns on at hi. It does not come on on switch 1 or 2....just on 3. I checked all fuses and all seems o.k..
Any advice is greatly appreciated.
Thanks,
Old Aug 20, 2008 | 06:42 PM
gemineye716's Avatar
Default Re: 1994 Honda Accord fan (blower) - heater/ac (nramil)
i had that same problem with this ol 94 mercury tracer 'beater' i useta drive around. i think it was the resistor block causing the problem. might be ur case as well
Old Aug 20, 2008 | 08:55 PM
nramil's Avatar
Default Re: 1994 Honda Accord fan (gemineye716)
resister block?
is this a DIY job or does it need a mechanic for repair?
Old Aug 20, 2008 | 09:08 PM
dtapia's Avatar
Default Re: 1994 Honda Accord fan (nramil)
very simple to replace.
sounds like the blower motor resister is failed when only the high speed works.
Old Aug 22, 2008 | 09:35 PM
nramil's Avatar
Default Re: 1994 Honda Accord fan (dtapia)
Thanks for the input....I'll change the blower motor.
Old Oct 9, 2008 | 07:37 PM
liznadrian's Avatar
i have a 94 accord ex and have the same problem, do i have to change out the blower motor as well? i turn on each speed and it does nothing but i see my climate control lights dim for a split second as im moving through the fan speeds1, 2, 3, and 4. i believe i am getting current but no air blows out the vent. i even checked under the hood fuse and everything is ok, thought it was a bad switch but when i switch it to #1 speed and hit the ac button it lights up and compressor starts running.
Old Oct 9, 2008 | 09:33 PM
bseriescrxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nramil &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the input....I'll change the blower motor.</TD></TR></TABLE>
blower motor has nothing top do with the resistor....they are two different things...im not exactly sure where it is on your accord but if you pick up a shop manual and get the part it should be a DIY job.....replacing the blower motor will do nothing for you
Old Oct 9, 2008 | 10:36 PM
liznadrian's Avatar
what about my situation, is it the blower motor? this sucks i need my heater and no air out the vents..
TheCoolNamesAre
Sep 8, 2018 09:55 AM
timmyb1985
Jul 9, 2018 01:18 PM
therest
Sep 23, 2014 07:36 PM
CommanderZero
Nov 21, 2010 04:28 AM
1josemedina
Oct 16, 2007 02:26 PM
