Is this normal when you chang clusters?
Old Aug 20, 2008 | 03:38 PM
mikeycivic's Avatar
Default Is this normal when you change clusters?
I had a ctr cluster in my car and it worked fine. I took it out and put in a si cluster. I believe when I put it in the gas needle was at the bottom. When I put it in and started the car it moved up to the full position. Is this normal? I let the car run for a while and it didnt drop. Any suggestions?
Old Aug 21, 2008 | 11:30 AM
mikeycivic's Avatar
Default Re: Is this normal when you change clusters? (mikeycivic)
Old Aug 21, 2008 | 11:33 AM
Hanmin's Avatar
ummm, is your gas full??? it reads your gas when your car is on, so its normal. unless your gas tank isnt full then you have a problem.
Old Aug 21, 2008 | 11:40 AM
mikeycivic's Avatar
Default Re: (Hanmin)
no my gas tank wasnt full, at least according to the ctr cluster that was in it befroe the si cluster
Old Aug 21, 2008 | 11:44 AM
Hanmin's Avatar
I think the cluster is bad, look at the back of the cluster, make sure nothing is burnt out. I had a cluster that burned out somehow and my tach didn't work.
Old Aug 21, 2008 | 11:49 AM
mikeycivic's Avatar
well it did move up its just reading wrong. Im going to take the clear cover off and push the needle down and see what happens
Old Aug 21, 2008 | 12:04 PM
suno's Avatar
Sell it on e-bay and get yourself another one lol
Old Aug 21, 2008 | 12:05 PM
sageuvagony's Avatar
Maybe someone pulled off the needle and didn't pop it back in the right spot? Who knows
Old Aug 21, 2008 | 12:06 PM
mikeycivic's Avatar
Default Re: (sageuvagony)
well it was a trade. Si cluster + cash for my ctr cluster but before I send the ctr i need to make sure the si cluster works
Old Aug 21, 2008 | 12:19 PM
Burnt Toast's Avatar
Default Re: (mikeycivic)
If you're swapping cluster for cluster, just swap over the fuel guages before you sent your ctr out.
Old Aug 21, 2008 | 12:21 PM
mikeycivic's Avatar
Default Re: (Burnt Toast)
nah im not pulling the needles off, there is always a chance they will break, if it dont fix itself Ill just send his money and his cluster back
maxwellmercer
Oct 26, 2008 10:03 AM
poppypizza
15
Jun 24, 2007 07:32 PM
SpleenBoy
Mar 4, 2006 04:34 PM
sf@rx7
Feb 17, 2006 07:42 PM
trooper0641
Sep 1, 2004 11:13 AM
