b16 boost (stock)
ok i got a 95 del sol with a swapped b16 from a 2000 si. i had a stock rebuild. port and polish and valve job done to it i just hit 9000 miles on the motor i wanna boost it, i was told putting a thicker head gasket would knock back the compression a little bit which is only 10:2:1 now. and retard the timing and get a good tune but everything else on the motor is brand new and i got all the bolt ons dont know if that matters though, and im only gona run like 6 or 7psi on it so if you know anything about boost let me know wat ya think thanks
leave the timming alone untill it is tunned cause diffrent motors on diffrent amounts of boost will react diffrent to a certain timing. but I run a stock gsr on 11psi and have had no problems so dont worry about the head gasket unless it is bad.
sorry i didnt get back sooner i was in florida on vacation but thanks for the tips guys helped out alot now i dont have to worry bout blowin it up lol ima go get me a bad *** tuner now thankis again
hillssol95
29
Nov 15, 2010 08:20 AM
