what ecu does the 90 ex sedan have?
Old Aug 20, 2008 | 01:28 PM
turboblack2door's Avatar
Default what ecu does the 90 ex sedan have?
I don't even know how to tell the differences
Old Aug 20, 2008 | 01:39 PM
1kleenef's Avatar
Default Re: what ecu does the 90 ex sedan have? (turboblack2door)
look on the side of the ecu its a pm6 ecu and by the way u really should SEARCH NEXT TIME
Old Aug 20, 2008 | 01:51 PM
Default Re: what ecu does the 90 ex sedan have? (1kleenef)
man i'm on dial up! Do you know how long it takes to search on dial up?
Old Aug 20, 2008 | 02:15 PM
honditacvcc's Avatar
im prety sure its pm6 because it **** with the d16a6 pgmfi but if i ure u id put in a pg7 from an 88 integra higher rev limiter better air/fuel maps
Old Aug 20, 2008 | 02:23 PM
Default Re: what ecu does the 90 ex sedan have? (honditacvcc)
I just got my turbo kit so i'm also wanting to know what ecu i should run. I don't plan on ever swapping a b series or a vtec motor so what would you guys recommend? I'm new to the whole honda ecu thing so please help
Old Aug 20, 2008 | 03:16 PM
sinepome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboblack2door &raquo;</TD></TR><TR><TD CLASS="quote">man i'm on dial up! Do you know how long it takes to search on dial up?</TD></TR></TABLE>
thats the best excuse i have ever herd for not searching. you should quote that in your sig. GL with the ecu
Old Aug 20, 2008 | 03:29 PM
sgallagher's Avatar
If you're going to turbo your car, I would suggest converting to OBD1 and running some type of alternative engine management system, i.e. Hondata etc. This way when you have the car ready to go you can have it tuned by a professional and will not spend tons of money and time leaning engines out and burning up pistons/valves etc...
Good luck.
Old Aug 20, 2008 | 04:41 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1kleenef &raquo;</TD></TR><TR><TD CLASS="quote">look on the side of the ecu its a pm6 ecu and by the way u really should SEARCH NEXT TIME</TD></TR></TABLE>unless the car is an automatic, then ECU is PS9
Old Aug 20, 2008 | 04:44 PM
Default Re: what ecu does the 90 ex sedan have? (sgallagher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinepome &raquo;</TD></TR><TR><TD CLASS="quote">
thats the best excuse i have ever herd for not searching. you should quote that in your sig. GL with the ecu</TD></TR></TABLE>
can i not run chrome or neptune on my car the way it is(with the ecu chipped?)
Old Aug 20, 2008 | 04:54 PM
jlicrx's Avatar
Crome and Neptune are for OBD1
Old Aug 20, 2008 | 05:03 PM
Default Re: what ecu does the 90 ex sedan have? (jlicrx)
what can i use for tuning for obd 0
Old Aug 20, 2008 | 05:22 PM
IHEARTMYHONDA91's Avatar
its a pm6
same as the crx si.
Old Aug 20, 2008 | 05:25 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboblack2door &raquo;</TD></TR><TR><TD CLASS="quote">what can i use for tuning for obd 0</TD></TR></TABLE>turboedit
Old Aug 20, 2008 | 05:38 PM
is turbo edit free? and do you have to socket the ecu for it or do you just get a programable chip?
Old Aug 21, 2008 | 09:17 PM
mario_pic's Avatar
it has a ps9 only ecu u can do a one wire vtec with and still retain ur ac pm6 can be made in to a ps9 but it will take a crap load of parts i got both laying around let me know if u need one i also got them chiped and converted to a jdm b16a ecu as well
Old Aug 22, 2008 | 06:54 AM
Default Re: what ecu does the 90 ex sedan have? (mario_pic)
well the vtec isn't of importance since i'm not going to have it. I'm talking with a local turner and he's telling me to convert to obd1 and use a p06
mugencx
Sep 26, 2007 06:35 PM
sireg6
Honda Civic (2001 - 2005)
Jun 25, 2007 12:05 PM
B16b-EJ8
11
Apr 3, 2007 10:30 AM
MANDO6669
Jun 2, 2006 08:39 AM
94Acura
Sep 10, 2004 04:53 PM
