SKUNK2 OR TYPE-R??????
Old Aug 20, 2008 | 01:27 PM
cavscoutnjtx's Avatar
Default SKUNK2 OR TYPE-R??????
hey whats a better intake maifold? the factory 01 tpe-r or should i swap it for the skunk2?
Old Aug 20, 2008 | 01:36 PM
pennies_hatchie's Avatar
Default Re: SKUNK2 OR TYPE-R?????? (cavscoutnjtx)
sk2 is a copy of the itr im. just stick with the oem setup unless you have a ported one with a ported TB and ported head to go with it
Old Aug 21, 2008 | 01:31 PM
Hooch'n's Avatar
Default Re: SKUNK2 OR TYPE-R?????? (pennies_hatchie)
Not sure if one is better, get the cheaper used or new of the 2.
I know for a GSR motor the Skunk 2 is much better and for a B16 the ITR made a large difference too.
Never used anything but ITR for the ITR stock motor.
Old Aug 21, 2008 | 03:00 PM
ivtecdriver's Avatar
stick with the type-r
Old Aug 21, 2008 | 03:16 PM
actionanh's Avatar
Default Re: (ivtecdriver)
i have the skunk2 pro series on my built head port matched to my 68mm professional products TB so I say skunk2 only if you are building....
Old Aug 21, 2008 | 06:33 PM
krytoi's Avatar
i just took of the type r one today and put on a skunk2 1st gen intake mani i like it more but im running a b16b in eg hatch
Old Aug 22, 2008 | 09:34 AM
Aquafina's Avatar
Default Re: (krytoi)
There is no difference. Skunk2 IM is a ITR copy. Skunk2 Pro IM is a fresh design.
Old Aug 22, 2008 | 11:13 AM
touchmyHONDA's Avatar
oem is best... unless its a gsr head
Old Aug 22, 2008 | 11:11 PM
neo_'s Avatar
Default Re: (touchmyHONDA)
The first gen one is a direct copy. And the pro one supposedly flows better.
Old Aug 23, 2008 | 01:55 PM
Rollo Lawson's Avatar
Default Re: (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">The first gen one is a direct copy. And the pro one supposedly flows better. </TD></TR></TABLE>
not true, the gen1 s2 im is not the same as an itr unit. it looks the similar, but, its different. i believe the s1 has a slightly bigger plenum and shorter runners. something like that
Old Aug 26, 2008 | 02:29 PM
Hooch'n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by touchmyHONDA &raquo;</TD></TR><TR><TD CLASS="quote">oem is best... unless its a gsr head </TD></TR></TABLE> Yeah, got the skunk2pro for the gsr motor
eg6turb0
Jul 27, 2004 05:05 PM
rough_draft
May 12, 2004 04:15 PM
JDMvtecDRAGSTA
11
Jul 28, 2002 10:45 PM
4potnick
May 5, 2002 02:56 PM
GReddySetGO
Nov 17, 2001 09:58 AM
