HELP a/c not working!!!
Old Aug 20, 2008 | 11:18 AM
exx07a0b's Avatar
Default HELP a/c not working!!!
i have a 93 civic si. I took off the a/c system and put it back in. I replace with a used ac compressor. Now it works off and on. It works one day and it does not.
any help well do. I was just think replacing the compressor but do i need a drier or etc. Thanks
Old Aug 20, 2008 | 06:07 PM
cjo_28's Avatar
Default Re: HELP a/c not working!!! (exx07a0b)
what is your high side pressure and what is the ambient temp? it should be at about 160 psi at 80 degrees and 1000 rpm.
If you don't know the basics of A/C work, you'll really need to find somebody that can help you.
Old Aug 20, 2008 | 07:33 PM
kisses's Avatar
Try to clean the compressor and if that wasn't the problem, probably the a/c unit. Try to check your wirings too.
____________________
<U>Autopartswarehouse is a must!</U>
tj051
Apr 13, 2012 07:18 AM
HondaChic01
May 7, 2011 08:16 PM
GSR936
25
May 14, 2010 07:47 AM
veggiemaster
Jul 17, 2005 08:46 PM
ludeR917
May 9, 2004 04:36 PM
