Cluster lights won't stay on
Old Aug 20, 2008 | 09:35 AM
webba1's Avatar
Default Cluster lights won't stay on
When I turn my head lights on (on the turn signal stalk) the cluster lights don't come one and the clock stays bright (doesn't dim). If I play with it for a minute or two I can get the lights to come on. I'm assuming there is a bad connection somewhere in the turn signal stalk and was wondering if anyone has seen this problem before and what they did to fix it?
Old Aug 20, 2008 | 01:10 PM
webba1's Avatar
Default Re: Cluster lights won't stay on (webba1)
bumb
Old Aug 20, 2008 | 01:11 PM
Ass$nyper's Avatar
Pirate General...YARRRR
sounds simple but have you looked at the bulbs?
Old Aug 20, 2008 | 03:05 PM
91_shoebox_Si's Avatar
Default Re: Cluster lights won't stay on (***$nyper)
i just replaced my bulbs behind my cluster and they were doing the same thing. seemed like they were shorting out. i just pulled the bulbs and GENTLY bent the connections in the bulb harness, 4 small pieces of metal the bulb slides into, together to create a tighter connection and problem solved. like snyper said. check your bulbs and their connections.
Old Aug 21, 2008 | 06:01 AM
webba1's Avatar
Default Re: Cluster lights won't stay on (91_shoebox_Si)
K, will do. But all the bulbs having a bad connection? and all the bulbs correcting the bad connection when I adjust the headlight switch on the stalk? I'll check it tonight, I've also got a spare stalk I may plug that up and see if it fixes the problem. I can at least localize the issue to one spot.
Thanks Guys!!!
Old Aug 21, 2008 | 07:56 PM
91CrxEF's Avatar
yeah i would just check bulb socket and make sure all are touching and if not i would trace wires and make sure no bad connections.
Old Aug 22, 2008 | 12:47 PM
webba1's Avatar
Default Re: Cluster lights won't stay on (91CrxEF)
Found it, turn signal stalk had a bad connection. Changed it out with a spare one I had layin around, works like a charm. Thanks guys.
maglites94
Lighting
Apr 13, 2012 08:11 PM
Stevo2427
Oct 4, 2007 10:40 AM
sicivic
Nov 14, 2004 08:37 AM
eclypzex
Aug 27, 2004 04:39 PM
