Lighting HID/Xenon kits, Retrofits and Associated Topics
LED cluster lights.
Old Apr 8, 2012 | 06:25 PM
maglites94's Avatar
Default LED cluster lights.
does anyone know wich bulbs are the main bulbs for the gauge cluster on a 93 civic ex?
also is there a number conversion on the bulbs?
last thing does anyone know where i can buy blue led bulbs for it?
Old Apr 8, 2012 | 07:50 PM
maglites94's Avatar
Default Re: LED cluster lights.
ttt
Old Apr 8, 2012 | 09:54 PM
blackmugensivic's Avatar
194
Old Apr 11, 2012 | 06:33 PM
LowTEC SaiMike's Avatar
superbrightleds.com
Old Apr 13, 2012 | 08:07 PM
uhhkilleez's Avatar
I just did the led swap on my Accord. #194 lit up the gauges and then #74 were for the rest like the odometer, all those lights that come on like the seatbelt and check engine light, and also those two little spot lights that shine on to the cluster. I think I used 5 #194's total.
Here's some before and afters. The only bulb that still worked was the one on the gas gauge. I only changed the #194 bulbs and colored the odometer light bulb with a red sharpie haha
There's a few hot spots but if you get those wide spread lights then it will probably look better.
The same #194 bulbs work in my map lights, door step lights, trunk light, and license plate lights as well so you can match all of those lights to the cluster.
Old Apr 13, 2012 | 08:11 PM
uhhkilleez's Avatar
These are the bulbs I used, got them at O'Reilly for $10 a pack. Only other color they had was amber though. Bought three packs and had one left over so I stuck it in the trunk light.
muddmonky
Oct 21, 2012 06:39 PM
JJGL-EF90
Feb 21, 2011 11:37 AM
webba1
Aug 22, 2008 12:47 PM
Stevo2427
Oct 4, 2007 10:40 AM
Integraoligist
Aug 22, 2005 09:28 AM
