My '91 D16A6...
Old Jul 23, 2002 | 02:09 PM
ex voto's Avatar
Default My '91 D16A6...
...is surging.
Usually only in first, second or third, but it is bucking a little bit once you approach 2300 RPMs. The check engine light is on, and other than that the car seems to run very well.
Any suggestions?
Old Jul 23, 2002 | 02:15 PM
Louie B.'s Avatar
Default Re: My '91 D16A6... (ex voto)
what code is the ecu throwing? (pull up the carpet on the passenger side footwell and turn the key to "on" possition, there will be a led on the ecu that will flash a sequence. count the flashes and post back here
Old Jul 23, 2002 | 02:35 PM
ex voto's Avatar
Default Re: My '91 D16A6... (thumpu77)
Damn... I didn't even think about that.
It's flashing nine.
Old Jul 23, 2002 | 02:49 PM
Art T. Fish L.'s Avatar
Have you FIRST checked to make sure there is oil in your engine?
Old Jul 23, 2002 | 03:27 PM
Louie B.'s Avatar
It's flashing nine.
I left my book at work, I can give you an answer tomorrow evening unless somebody else has by then.
Old Jul 23, 2002 | 06:16 PM
[626]95-GSR's Avatar
Ahhhh... a very common problem. It lies within your distributor... Its missing due to the crank angle sensor. Code 9 = No. 1 cylinder position... While its OK to continue driving with it... you will want to fix it soon, as it will eventually fry your distrib.. The bucking of the motor will also do damage to your mounts and tranny and such.. I would suggest getting a WHOLE other distributor.. or just try to fix the Crank Angle sensor itself, it consists of a number of color coded wires..
Old Jul 23, 2002 | 07:36 PM
USDM 4G VTEC's Avatar
Default Re: My '91 D16A6... ([626]Rj-SiHatchy)
No 1 CYL sensor
i got the same code and cant fig out how to fix it..
if someone has let me know
and by the way Sihatchy i love ur signature!
Old Jul 24, 2002 | 12:43 PM
ex voto's Avatar
Default Re: My '91 D16A6... (JDM EF9)
Well, poopscotch. Is the sensor hard to replace, or would a distributor be the easiest route?
Old Jul 24, 2002 | 12:48 PM
Bgladfelter's Avatar
well, I could only find the ZC's teg one on an Acura parts online store, and its was 105$. I got a reman from Advance with new cap and rotor for 226 after tax.
Khrystin
Sep 10, 2018 04:12 PM
Silent Knight
Jun 28, 2005 06:29 AM
richie3925
Oct 19, 2004 05:33 PM
ImportechPerformance
May 28, 2002 07:17 AM
W0oT
Jun 18, 2001 01:47 PM
