need to know about wiring harness
Old Aug 20, 2008 | 12:51 AM
95civic24's Avatar
Default need to know about wiring harness
will d16z6 wiring harness work on a d15b ? it is for a 95 civic
Modified by 95civic24 at 4:15 AM 8/21/2008
Old Aug 20, 2008 | 01:02 AM
raidacaipo's Avatar
Default Re: need to know about wiring harness (95civic24)
It should. but remember to use your original wire harness that came with the car and retro fit it into the new motor your swapping in.
Old Aug 20, 2008 | 01:09 AM
95civic24's Avatar
Default Re: need to know about wiring harness (raidacaipo)
ok thinks what about the header?
Old Aug 20, 2008 | 06:22 AM
94EG8's Avatar
Seagull Management
If its a JDM D15B vtec use whatever header/manifold is in better shape, if its non-vtec then i'd just reuse the old Z6 manifold.
Old Aug 20, 2008 | 08:53 PM
95civic24's Avatar
Default Re: need to know about wiring harness (94EG8)
so JDM D15B vtec so i can use the z6 header?
Old Aug 21, 2008 | 03:04 AM
94EG8's Avatar
Seagull Management
Yes, the factory manifold and downpipe are identical between the two.
96$jdmb$16a
Jun 1, 2009 09:55 PM
crazy-teggy-ls
May 5, 2009 08:20 AM
puertoricanboy90
14
Aug 7, 2008 10:09 AM
NatedoggAZ
Jul 21, 2003 02:47 PM
fOmaNPu
Oct 3, 2002 07:46 AM
