all motor gsr question
Old Aug 19, 2008 | 10:14 PM
autoxgsr's Avatar
Default gsr setup- jun 2 cam
Hi i was wondering how much hp this setup will give me. Gsr head 3 angle valve job pnp, jun 2 camshaft, cam gear, supertech valves and retainers, msd box, msd wire, dsm 440cc injector aem cold air intake, dc 4-2-1 header, custom 2.5 exhaust, arp head stud, ctr pistons and ring, usdm gsr tranny no lsd, uberdata ecu? compression should be 12.0-12.5? Thanks.
Modified by autoxgsr at 11:58 PM 8/19/2008
Old Aug 20, 2008 | 01:31 AM
SleeperGSR's Avatar
Default Re: gsr setup- jun 2 cam (autoxgsr)
build it and dyno it.
Old Aug 20, 2008 | 06:23 AM
neardon's Avatar
I'm a Jackass
You dont need the msd box or wires, NGK works fine. DC headers suck, you should look at tri-y setups. By "custom" 2.5 exhaust i hope you dont mean "crush bent". Uberdata is good for people on a low budget but why would you $2000+ on a all motor setup then cheap out on the ecu? If you dont get it tunned right all those parts are going to be useless, get hondata and have a professional tune it.
Old Aug 20, 2008 | 08:03 AM
B18CEJ205's Avatar
too many variables to tell you what you'll make. Like sleeper said, build/dyno it. Until then we could all just throw #'s at you but it would be pointless. And I second on the ECU.. if you're gonna put that much money down, why not throw out $550 or so for a Hondata S300?
egcivic92
May 16, 2008 09:17 AM
Pandahatch
Feb 2, 2008 02:27 PM
slowestcarever
32
May 2, 2004 09:00 AM
slowestcarever
Apr 23, 2004 05:04 PM
DLB1994
Mar 1, 2003 12:57 PM
