Classic Hondas All Pre-1988 Hondas.
87 Accord Won't stay running when in nuetral or clutch is pushed in.
Old Aug 19, 2008 | 07:44 PM
Accord1987's Avatar
Default 87 Accord Won't stay running when in nuetral or clutch is pushed in.
I have a Carburated accord dx 5 speed that won't stay running when I push the clutch in or when it is in nuetral unless I hold the throttle a little. I replaced the plugs, cap and rotor, pcv valve and did a oil change and still no luck. I thought maybe the cat was clogged so i hollowed it out since I don't have to worry about DEQ. Also when I changed the plugs a couple of them were a red color and the exhaust seems to be a little on the hot side. thinking maybe the O2 sensor is bad but not sure how to check it and don't want to waste the money on one if I don't need it. other wise the car runs great under power besides a little bit of studering at a steady speed. Any help would be appreciated.
czego82
Oct 11, 2017 11:55 AM
phillyfan1028
Oct 12, 2009 02:25 PM
Accord1987
Classic Hondas
Aug 18, 2008 07:03 PM
tekraid
Aug 17, 2003 06:18 PM
