2011 Accord Clutch Issue
Hello
I just got a 2011 2-door 4cyl accord with clutch issue. I knew about it while buying but price was too good to pass up even if I have to replace it.
The issue is that when releasing the clutch in first or second gear, the car does not start moving till it is almost fully released. Normally, when the pedal is half way out if would start moving and by the time it is 3/4 of the way out, it would be mostly disengaged. There is no smell of it burning and everything seems fine so I was wondering if anyone know what could it be? Is there a way to adjust it? or does it basically need to be replaced. I know if I take it to the dealer, they will recommend the most expensive option which is replacement. Any ideas?
Thank you
Thank you
phillyfan1028
10-12-2009 02:25 PM
