battery problem
i have the 2004 honda accord, v6. few days ago, i didn't start my car and i turn on the cd player from about 11:30 am to 3-4 pm, and when i tried to start my car, it couldn't start, and then i jumped it, and it could start, does any one think is there something wrong with the battery? do i need to replace it? how much does it cost ? thanks for answering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedValve »</TD></TR><TR><TD CLASS="quote">have it checkd out by ur local autozone, its often the batteries. it should cost around 80+</TD></TR></TABLE>unless you're getting a gold series it should be alot cheaper then $80.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjo_28 »</TD></TR><TR><TD CLASS="quote">4+ hours with the key in the on position will usually drain a good battery, too. </TD></TR></TABLE>
Exactly.
If you like to run your stereo for extended periods invest in an optima. I've run the system in my Accord for over 12 hours and had it start right up.
Although one thing to remember with Optima batteries is that if you do drain them low you need to actually hook them up to a trickle charger and give them a long charge to keep them in good shape.
Exactly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord1234 »</TD></TR><TR><TD CLASS="quote">I still wouldn't wanna go that many hours even with an optima. Seems like a long time</TD></TR></TABLE>
Bit more than a stock system as well.
It was kind of a test though. I had a jump box with me just in case but I certainly didn't need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord1234 »</TD></TR><TR><TD CLASS="quote">Do you have the yellow top or red top?</TD></TR></TABLE>
Red Top.
Red Top.
hon da top
Mar 28, 2008 06:57 PM
MooreBoost
Aug 31, 2005 08:53 PM
