alignment off after rear discs
Old Aug 19, 2008 | 04:25 PM
Mr_Moos's Avatar
Default alignment off after rear discs
swapped rear discs off a 92 integra
rear toe is off 1.4 degrees
was i suppose to swap one of the arms or what?
Old Aug 19, 2008 | 04:35 PM
beana's Avatar
Default Re: alignment off after rear discs (Mr_Moos)
bring into a auto shop and get alighnment ,or you can string it and do it yourself
Old Aug 19, 2008 | 08:42 PM
Tyson's Avatar
no, you need to get an alignment. you cant expect a whole new trailing from another car to be exactly the same alignment.
Old Aug 20, 2008 | 03:44 AM
juandaman's Avatar
Do some research but if I remember correctly your supposed to use the EFs LCAs!
Old Aug 20, 2008 | 07:19 AM
Vinceg99's Avatar
Default Re: alignment off after rear discs (juandaman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juandaman &raquo;</TD></TR><TR><TD CLASS="quote">Do some research but if I remember correctly your supposed to use the EFs LCAs!</TD></TR></TABLE>
No you can use the integra lca's BUT you do have to use the compensator arms off of the EF they are what adjusts the toe in and toe out they are longer on the intergra and also if you would have unbolted those from the trailing arm instead of the body you may not have needed an alignment.
Old Aug 20, 2008 | 07:54 AM
RB_EJ8's Avatar
Default Re: alignment off after rear discs (Vinceg99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">
No you can use the integra lca's BUT you do have to use the compensator arms off of the EF they are what adjusts the toe in and toe out they are longer on the intergra and also if you would have unbolted those from the trailing arm instead of the body you may not have needed an alignment.</TD></TR></TABLE>
I have the same issue with my EF. I swapped everything from a DA. Can I just get a camber kit to remedy the compensator arm. My rear wheels look like there going inward. Somebody help
Old Aug 20, 2008 | 07:57 AM
Ermil's Avatar
Just got done with this swap myself and had the same exact problem. Integra compensator arms are too short, sucking the wheels in. Use the EF compensator arms and get the allignment set. You'll be golden like a shower.
Old Aug 20, 2008 | 08:21 AM
Vinceg99's Avatar
Default Re: alignment off after rear discs (RB_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RB_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
I have the same issue with my EF. I swapped everything from a DA. Can I just get a camber kit to remedy the compensator arm. My rear wheels look like there going inward. Somebody help </TD></TR></TABLE>
Camber kit wouldnt help considering thats for camber and you have a toe problem either get the stock compensator arms or they do make adjustable compensator arms (not sure who makes them, where to get them, or price) but best bet just get a set of the original compensator arms hell I may even have a set
Old Aug 20, 2008 | 08:24 AM
JDM CERTiFiED's Avatar
also if its lowered get a camber kit
Old Aug 20, 2008 | 09:22 AM
Tyson's Avatar
Default Re: (JDM CERTiFiED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CERTiFiED &raquo;</TD></TR><TR><TD CLASS="quote">also if its lowered get a camber kit</TD></TR></TABLE>
um no, if its lowered get an alignment.
thats the only rule.
Old Aug 20, 2008 | 03:45 PM
Vinceg99's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
thats the only rule.</TD></TR></TABLE>
Well depending on how low you go I would say anything less than 1.5" you dont but anything more you should.
Old Aug 20, 2008 | 04:00 PM
EFstyle's Avatar
Default Re: (Vinceg99)
Well depending on how low you go I would say anything less than 1.5" you dont but anything more you should. </TD></TR></TABLE>
.... had tein s-tech's on my old ek and no need for an allignment...
Old Aug 20, 2008 | 04:16 PM
Mr_Moos's Avatar
ok thats what i did wrong
i work at a dealership alignments are free
i said it was off 1.4 degrees did people not get i already had the car on the alignment rack or what
Old Aug 24, 2008 | 10:45 PM
RB_EJ8's Avatar
Default Re: alignment off after rear discs (Ermil)
I replaced the DA with my stock EF compensator arms. Mo' Betta! Good lookin out!
Old Nov 30, 2010 | 06:19 AM
AZGS00's Avatar
this thread is quite informative so im resurrecting it since im having the same issue
Summary:
-DA rear LCA's (for use with DA swaybar)
-Integra RTA's
--Need to use EF civic compensator arm (toe arm at front of RtA) to allow for proper toe
because the DA one is too short!
Old Nov 30, 2010 | 07:19 AM
asianflava's Avatar
To put it in simple terms: Mess with the suspension, and you mess with the alignment.
They measure your alignment in tenths of degrees and 1/16ths of an inch. It's pretty hard to get it exactly where it originally was.
Old Nov 30, 2010 | 12:21 PM
spcrxracer's Avatar
Thanks for contributing absolutely nothing to this thread.
Old Nov 30, 2010 | 12:36 PM
Tyson's Avatar
Um wtf, that was a very informative post.
Ur pic is stupid. So was your useless post.
Old Nov 30, 2010 | 12:59 PM
mruneek's Avatar
agreed
Old Nov 30, 2010 | 01:01 PM
mitsubishiv5's Avatar
i dont even need to read the rest:
Bet you used the integra toe arms. your supposed to use your ef toe arms for the correct toe. the other toe arms are too short
Old Nov 30, 2010 | 01:20 PM
FSRslug's Avatar
Nice job. If you bothered to read the thread you would see that this was already determine to be the cause and it was determined over 2 years ago. You're just a bit late.
Old Nov 30, 2010 | 02:14 PM
asianflava's Avatar
Looks like you are the one not contributing anything to the thread. And if you had bothered to look carefully, I didn't dredge this thread up, there is a post before mine.
Old Nov 30, 2010 | 02:17 PM
nope didnt try
Old Dec 1, 2010 | 09:08 PM
AZGS00's Avatar
EF toe link: 17cm
DC/DA toe link: 14cm
EF/DC/DA/EG LCA: 34cm (end to end holes, shock mount is further inboard on DA lca which doesnt affect alignment)
fWIW
JDMchucko
11
Oct 25, 2010 04:43 PM
88 civic ef
13
Jan 2, 2008 04:31 AM
JDMThoughts
Mar 21, 2005 03:41 PM
litterbox
21
Feb 16, 2005 10:07 AM
91SIR
Apr 22, 2003 01:56 PM
