Upper Control ("A" arm) bushings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos »</TD></TR><TR><TD CLASS="quote">If they look dried out, cracked etc. If you can move the arm side to side when the bolts are tight.</TD></TR></TABLE>
if you need some new one just replace them. you dont need to get a whole new upper control arm.
http://www.statracing.com/oem-...39393
if its an OEM arm then yeah u have to replace the whole arm. if you buy aftermarket then the ball joint has a c clip on it and u can just replace the ball joint and not the whole arm.
i was told that you could change the upper ball joint on a stock control arm from auto zone, and mechanic say i need the whole arm and ball joints, is this correct? need to know buy today so i can buy the right stuff.
tom2000
Nov 29, 2010 06:53 PM
