JDM All Motor B18C
Hi Everyone,
I am new to Honda, new to japanese cars, and new to the forum.
I was considering a project car however, such as a civic hatch or coupe. I know a japanese auto parts place that gets these JDM engines from japan. I was reading alot on The B18C (TYPE R) engine. now it produces roughly 200HP. I was told that these are some of the most highest revving engines, and most reliable engines. I would like to build this engine around a Street / Road Racing Application so streetable for daily use and high revving high strung for the track. I was looking to get about 250WHP ALL MOTOR that is. What steps should I take in order to achieve this? What are some good parts? ECT....
Thanks
Thanks
If you want 250 HP All motor, then I would suggest going K20. I'm no expert and correct me if i'm wrong, but to get 250 whp out of a B18 is a lot harder to get then out of a K20. Defcon racing built a DC K20 all motor, putting out over 250 to the wheels and I also believe that the engine internals were stock. They are located in Thornhill. http://www.youtube.com/watch?v...lated
Modified by Mr.x at 3:07 PM 8/20/2008
Yeah it’s easy to say it, k20 cost more and installing the k20 is way harder then b18c. Ill you need to get a jdm b16 170hp with some modification you should be able to put 220whp and it wont cost u as much as k20 and b18c.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artin01 »</TD></TR><TR><TD CLASS="quote">Yeah it’s easy to say it, k20 cost more and installing the k20 is way harder then b18c. Ill you need to get a jdm b16 170hp with some modification you should be able to put 220whp and it wont cost u as much as k20 and b18c.
Making 220 whp on stock B16 sleeves NA is gonna cost you a whole lot of cheddar. Look at what Omniman had to go through just to break 200 whp.
</TD></TR></TABLE>Making 220 whp on stock B16 sleeves NA is gonna cost you a whole lot of cheddar. Look at what Omniman had to go through just to break 200 whp.
Right On. Like I said i am new to Honda, I would like to know what the best engine to get and what the best bang for the buck is. Everyone i know who has a honda keeps telling me to get a JDM B18C but if it's gonna cost big money to get some HP then what is a good engine combo for the dollar. I mean and what are realistic horsepower gains from these engines. I won't buy an engine thats like crazy expensive and I need to dump more $ on top of that to get desired horsepower gains. what is a good platform to start out with in order to get some decent horsepower. I am saying 200WHP - 250whp Evem 180whp is good.
Ideas please.
Thanks
Ideas please.
Thanks
H2B
Cams, header, manifold, TB . . .
220-240hp and more torque than a built b series . . . all on a stock block , stock port head. .
With the money you saved over a k swap you can even afford to take the ladies out and show them your mad vtak yoooo
nitrous is an easy cheap way to achieve that, a b18c should take a 50 shot with no problem, however the OP said he wanted to take it road racing.
i have to agree with the other posters, if you are going to build an engine the type r is a waste of money.
b20/vtec would be the wisest, and cheapest way of making that power. also the easiest due to the increase in displacement.
or you can go H22A/B16 trans for less than a k20 and really achieve that power goal easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR »</TD></TR><TR><TD CLASS="quote">H2B
With the money you saved over a k swap you can even afford to take the ladies out and show them your mad vtak yoooo</TD></TR></TABLE>
LMAO
MY VTEC IS IN A BOX
instead of my dick in abox .. you know?
LMAO
MY VTEC IS IN A BOX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R »</TD></TR><TR><TD CLASS="quote">
LMAO
MY VTEC IS IN A BOX
instead of my dick in abox .. you know?</TD></TR></TABLE>
LMAO
MY VTEC IS IN A BOX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">
lmao..
</TD></TR></TABLE>lmao..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryno00 »</TD></TR><TR><TD CLASS="quote">just get a gsr motor and build the head, you will get close to 250 depending how far you go with it.</TD></TR></TABLE>
Not 250 whp on a stock GSR with stock sleeves you won't. Maybe 220 whp fully build head and mad tunning.
I know of a guy who sent his head of to skunk2 and he redlines at 10,500... All day... And its a b16. So Any B series can rev high. It just depends on who does the work.. and if its done properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JulioRX »</TD></TR><TR><TD CLASS="quote">I know of a guy who sent his head of to skunk2 and he redlines at 10,500... All day... And its a b16. So Any B series can rev high. It just depends on who does the work.. and if its done properly.</TD></TR></TABLE>
What does the build consist of?
Port n' polish... FULL skunk2 valvetrain and i believe stage 3 camshafts? Might be wrong. I could ask if youd like. Everybody knows skunk2 is no BS so if you could afford that give them a call and send off that head
Modified by JulioRX at 1:22 PM 8/26/2008
