obd1 o2 wiring question
Old Aug 19, 2008 | 05:17 AM
DEPintheCurve's Avatar
Default obd1 o2 wiring question
Hi guys,
My friend sold me his pair of headers for my mini-me. I been starting to wire the o2. I got the obd0 - obd1 conversion harness for the p28 off of phearable and some instructions came with for wiring the o2 sensor. However, two of the o2 wires are black and i dunno which is which.
Here is what the instructions say...
1. connect brown wire (harness) to one of the black wires on o2 sensor (heater control)
2. connect purple (harness) to green o2 sensor wire (o2 ground)
3. connect yellow (harness) to one of the black o2 wires (o2 12V signal)
4. grey harness to white o2 sensor (o2 signal)
So obviously it matters which black wire is which, right? I cannot see either of them working, but somebody please confirm. Should I hold off on soldering these two together, and make sure they work first?
Old Aug 19, 2008 | 10:57 AM
Default Re: obd1 o2 wiring question (DEPintheCurve)
Somebody gotta know...
Old Aug 19, 2008 | 11:18 AM
Creator's Avatar
I'm not certain but I don't think it matters. Let me see if I can look through my info here and confirm. You could always just twirl them together temporarily and see if it flys.
Old Aug 19, 2008 | 11:25 AM
Default Re: obd1 o2 wiring question (Creator)
Okay... Thanks. Yes please let me know... The instructions from phearable.net do not elicit that there is a certain order, but I want to be sure cause in the end I will be soldering these wires...
Old Aug 19, 2008 | 11:38 AM
Creator's Avatar
As your harness is different the colors will differ but the last page on this link should help you out:
http://www.boomslang.us/obd0_1.pdf
A couple of suggestions though
-Read the whole link if your still not sure.
-O2 sensors can be very temprimental (aka the new one you have may malfunction very quickly...especially if it has been mishandled) you might want to consider some kind of connector instead of hard wiring it. Most 4 wire connectors from a OEM plug will work with a o2 sensor made for a Honda/Acura.
ReactioN
Sep 7, 2008 09:45 PM
Hondamonster
12
Jun 21, 2007 08:19 PM
TrueNorthStar
Jun 8, 2004 04:49 PM
vladd
Dec 5, 2003 08:42 PM
Ruby Civic
Jun 15, 2003 05:57 PM
