GS-R vs ITR LCA's
First off the car in question is a 92 civic hatch with tein flex. And the question is... either lca going to perform better/be stronger. I really just want to kno will I feel any difference!
Oh also ITR 22 sway/spoon bar/beaks kit are goin on as well.
*aftermarket is out of the question so please do not go there*
first of all.
itr lcas r competely different than gsr lcas.
the shock sits inside the LCA for the itr.
whereas, every other lca, the shock sits ontop and on the outside of the lca.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiggieBert »</TD></TR><TR><TD CLASS="quote">And the question is... either lca going to perform better/be stronger.</TD></TR></TABLE>
No.
And as mentioned, you can't use the ITR rear lower control arms with your existing shocks anyway. They require a lower eye-type mount instead of the fork-type mount found on your Civic.
Since the Type Flex is a fixed-stroke damper, you should be able to remove the lower mount completely from the threaded body and replace it. Contact Tein to see if they will sell you the ITR-style lower mounts separately.
No.
The ITR vs GSR LCA's have different motion ratios. The shock mount point is further inboard in the ITR LCA, so what that means is that it will make the springs feel very slightly softer. Very slightly. You may as well base your decision on what shocks you want to get in the future. A lot of bling JDM stuff is for the ITR type mounting points anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanbag »</TD></TR><TR><TD CLASS="quote">The ITR vs GSR LCA's have different motion ratios. The shock mount point is further inboard in the ITR LCA</TD></TR></TABLE>
Proof?
Proof?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Proof?</TD></TR></TABLE>
I measured them. The GSR motion ratio is .75 and the ITR ratio is .70
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiggieBert »</TD></TR><TR><TD CLASS="quote">Is it better to have the lower number? sorry if its a dumb qestion</TD></TR></TABLE>
Since you get to choose the spring rate, it doesn't really matter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanbag »</TD></TR><TR><TD CLASS="quote">I measured them. The GSR motion ratio is .75 and the ITR ratio is .70</TD></TR></TABLE>
What is the difference in position (mm)? I'd like to add this to my records.
I measured both lcas to be 13 7/16 inch from subframe bushing to TA bushing. The GSR shock mount bushing is 3 5/16 away from the TA bushing, and 3/4 below the line connecting the subframe bushing to TA bushing. The ITR mount point is 4" away from the TA bushing, and 1/4" down. All measurements are +/- 1/16.
comptechgsr
Sep 15, 2002 12:00 AM
thanks 4 the quick reply's!
