LS Crank position Sensor (CKP)
Old Aug 18, 2008 | 11:07 PM
kaddi88's Avatar
Default LS Crank position Sensor (CKP)
I checked my codes and it had 4 flashes (crank positin sensor <CKP&gt.
I think i found the harness for it, but how do u fix or replace the Sensor. Is it through timing tensioner or do u have to replace the whole sensor. I searched for this but i came up with nothing. So if there is a post can u please let me know. Thanx
Old Aug 20, 2008 | 09:30 AM
vshavoc's Avatar
Default Re: LS Crank position Sensor (kaddi88)
it should be below the crank pulley but you have to pull the lower timing cover to get to it so the crank pulley will have to come off to get to it.
Old Aug 23, 2008 | 10:20 AM
idpihb-teg's Avatar
i am going through the same problem with my gsr... does anyone know of a way to by pass the sensor so i can drive it to the honda dealer instead of getting it towed and if it is by passed will it harm anything
Old Aug 23, 2008 | 08:02 PM
mr.beeks's Avatar
Default Re: LS Crank position Sensor (idpihb-teg)
no bypass its the sensor that tells the ecu
when piston number 1 is TDC
Top
Dead
Center
Old Aug 25, 2008 | 05:14 PM
kaddi88's Avatar
Default Re: LS Crank position Sensor (mr.beeks)
K, im almost sure it was/is my piston #1. thats the one i had a spark plug problem with. so does it just need to be tuned again.? and can that make the distributer go out? Cuz no the engine turnes over but doesnt start at all, and backfires. so intern its undriveable. let me know what u think
Natie Barnard
Honda CR-V & Element
Jan 16, 2019 06:38 AM
rotten
Sep 25, 2005 06:18 PM
