need help badly
If someone on here has facebook please let me know. I need help and cannot post my pictures for the information I am looking for. Tonight my car bogged for 20 minutes not even revving past 300 rpm. On top of that it is running rich all the time unless I hit like 80 to 100 mph. Engine light stays on and code readings for O2 sensor, throttle body and map sensor flash. Have reset the ecu but then then car boggs etc but still runs rich as well. Have all the pictures on my facebook. Steve Bedell is my name. Thanks for all the help to those that are giving me advice ahead of time, I apoligize for being a pain in advance as well.
you might want to follow this thread as well.. this guy seems to be having the same problems .. https://honda-tech.com/zerothread/2368465
the o2 sensor and map sensor would make it run really rich so i would make sure that there both plugged in and workin and the code for the throttle body are you sure it isnt for the tps?
Also have a brand new O2 sensor just put in. They have wiring for a secondary O2 sensor just cannot find the post I seen the other night to make sure the wiring is correct
Dan_si_ej8
Engine Management and Tuning
Jul 8, 2017 10:18 AM
deftones0817
Sep 20, 2005 05:58 AM
