leaking radiator hose did search need anwser
Old Aug 18, 2008 | 11:08 AM
steveharrmr23's Avatar
Default leaking radiator hose did search need anwser
i have a brand new radiator from yonaka motorsports and my upper radiater hose leak where the hose attaches to the radiater before you ask yes it has new hose and new hose clamp the kind you screw and yes they are tight if i tighten them anymore the clamp might break please help i want it to stop i do not care how getto the suggestion is i just want it to stop really badly
Old Aug 18, 2008 | 12:06 PM
Default Re: leaking radiator hose did search need anwser (steveharrmr23)
is it possible to tighten a hose clamp to much
Old Aug 18, 2008 | 01:15 PM
hon2984's Avatar
of course
did u just install it all?
maybe there should have been some teflon tape on the threads or a rubber o-ring that got looked over in the install process?
Old Aug 18, 2008 | 04:51 PM
Default Re: leaking radiator hose did search need anwser (hon2984)
it is a radiator hose not a fuel line there is no threads or oring for a radiator
Old Aug 18, 2008 | 05:48 PM
Circusraven's Avatar
maybe you did tighten it too much and you crimped the inlet pipe. Remove the hose and check to see that the pipe is still round and not oval shaped.
Old Aug 18, 2008 | 05:54 PM
hon2984's Avatar
Default Re: leaking radiator hose did search need anwser (Circusraven)
i was thinking after market radiator with threaded ends n steel braided lines for some reason.
if you can break the inlet with a hose clamp u need a girl cause that forearm would be pretty strong.
Old Aug 19, 2008 | 05:48 AM
i know i am getting pissed about it i am about to try using an exhaust clamp
Old Aug 19, 2008 | 03:25 PM
hon2984's Avatar
maybe u will have a better idea if u throw a pressure tester on it!
oddmut
Apr 25, 2008 10:38 AM
Integra_RS
Mar 24, 2005 01:16 PM
01ITR#700
May 20, 2004 02:22 PM
WRTEG
Apr 3, 2004 04:59 AM
goforbroke
Jan 21, 2003 07:59 AM
