BLOX CAM Question, Stage 1 VS Type A
Old Aug 18, 2008 | 08:44 AM
b20beast83's Avatar
Default BLOX CAM Question, Stage 1 VS Type A
Hello guys
From the BLOX Racing Website
http://bloxracing.com/prod_camshafts.asp
There is a TYPE A and Stage 1 Camshaft for the B Series.
type A has the following spec:
Intake (lift / duration)
0.462" / 247
Exhaust (lift / duration)
0.420" / 239
and stage 1 has the following:
11.9mm / 264
11.0mm / 259
Anyone has any idea which cam should be the better choice?
I have a B16A Engine.
Hytech Replica header
2 1/2" Exhaust
Sri
MIGHT be doing a CRVtek
Old Aug 18, 2008 | 09:09 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: BLOX CAM Question, Stage 1 VS Type A (b20beast83)
Lift on the stage 1 is greater than the Blox A.
The stage 1 will require aftermarket springs and retainer.
Old Aug 18, 2008 | 01:47 PM
b20beast83's Avatar
Default Re: BLOX CAM Question, Stage 1 VS Type A (mar778c)
which cam would you recommend
Old Aug 18, 2008 | 01:52 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast83 &raquo;</TD></TR><TR><TD CLASS="quote">which cam would you recommend</TD></TR></TABLE>
I've had success with the Blox A's.
Here's a couple of my dyno threads
B18C1
https://honda-tech.com/zero...ge=15
B16A
https://honda-tech.com/zerothread?id=2000323
Old Aug 18, 2008 | 11:39 PM
Dark@Powers's Avatar
I was under the impression that Blox's main line of cams were "type" cams, not "stage", this jumbles things up a bit.
Old Aug 19, 2008 | 04:28 AM
IntegraType-R's Avatar
Default Re: BLOX CAM Question, Stage 1 VS Type A (Dark@Powers)
same thing really..
Old Aug 19, 2008 | 02:08 PM
Default Re: BLOX CAM Question, Stage 1 VS Type A (IntegraType-R)
I'm not saying that the fact that they are "type" and not "stage" changes specs or anything, but the line of cams that has nearly identical specs to the Stage 1-3 Skunk2 cams are the "type" A-C's from Blox correct? I thought the whole point of naming their main line type was to differentiate themselves from Skunk2, and any following accusations that they copied their cams...
Old Aug 19, 2008 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark@Powers &raquo;</TD></TR><TR><TD CLASS="quote">I'm not saying that the fact that they are "type" and not "stage" changes specs or anything, but the line of cams that has nearly identical specs to the Stage 1-3 Skunk2 cams are the "type" A-C's from Blox correct? I thought the whole point of naming their main line type was to differentiate themselves from Skunk2, and any following accusations that they copied their cams...</TD></TR></TABLE>
1) they did copy they're cams
2) i believe they do infact use Type a - c to be = to skunk2's stage 1-3.. however i've seen many cases where the measurements are different..
Old Aug 19, 2008 | 04:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">
2) i believe they do infact use Type a - c to be = to skunk2's stage 1-3.. however i've seen many cases where the measurements are different..</TD></TR></TABLE>
Yea, it's weird how they have two subcategories, not including the turbo cams, in their "Tuner" series though.
Old Aug 20, 2008 | 06:53 AM
b20beast83's Avatar
bump for more info
xkrazyxjbrkerx75
Nov 4, 2009 10:48 PM
xDicktonesx
160
Oct 28, 2006 06:16 PM
an2ny888
May 21, 2005 08:58 PM
crackerjacker006
Oct 31, 2004 09:11 AM
Green_Goblin
Oct 23, 2004 06:48 PM
