69mm TB vs ITB - Which would you go for?
Old Aug 17, 2008 | 07:02 PM
Johnny_9's Avatar
Default 69mm TB vs ITB - Which would you go for?
Old Aug 17, 2008 | 07:43 PM
Mike@Highend Autosports's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (Johnny_9)
it all depends on what your goal is and what type of budget is. I run TWM itb's on my race car and my street car.
Old Aug 26, 2008 | 08:09 AM
Johnny_9's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (Mike@Highend Autosports)
what kind of ecu/mgt do u run?
how was the itb installation?
do u run a cold air intake/cowl with the ITB?
Old Aug 26, 2008 | 12:35 PM
killerpenguin21's Avatar
the general rule of thumb is if you have to ask then your not ready for itb's.
What's your setup?
Search...there are plenty of threads by me, d-rod, and integra-typer dealing with itbs and a decent amount of tech.
Until then I suggest you stick to a professional proxy ts 68mm tb.
Old Aug 26, 2008 | 01:29 PM
Bisimoto's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (killerpenguin21)
Both Mike and I run AEM EMS' with our ITB setups. You cannot go wrong with Kinsler ITBs:
..and those are for the K-series.
On my street setup:
Old Aug 26, 2008 | 02:13 PM
white rocket's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (Bisimoto)
^^^crazy looking set-up . Are those fuel injetors shooting towards the air horns? What is the purpose of that?
Old Aug 26, 2008 | 04:50 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: 69mm TB vs ITB - Which would you go for? (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">^^^crazy looking set-up . Are those fuel injetors shooting towards the air horns? What is the purpose of that?</TD></TR></TABLE>
Better fuel atomization. Formula One cars use a similar setup.
Old Aug 26, 2008 | 09:08 PM
Colt Seavers's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (emotionisdead)
They work like this
http://www.youtube.com/watch?v=y2iBbwocYZw
Old Aug 27, 2008 | 05:03 PM
GSRswapandslow v2's Avatar
are those ford 42lb injectors???
Old Aug 27, 2008 | 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny_9 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of ecu/mgt do u run?
do u run a cold air intake/cowl with the ITB?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto &raquo;</TD></TR><TR><TD CLASS="quote">Both Mike and I run AEM EMS' with our ITB setups. You cannot go wrong with Kinsler ITBs:</TD></TR></TABLE>
Thank's Bisi. I also run a Hondata s300 on my street car and both ems system's work great. I would also recomend getting a set of TWM itb's. Check them out http://www.twminductions.com I also run the top feed injection on my Racecar. If you would like to see a set installed goto my web sit and goto the gallery http://www.Highendautosports.com
Old Aug 28, 2008 | 03:53 AM
vinuneuro's Avatar
On my street setup:
For a street engine, how do you use a filter with the way that's set up?
Old Aug 28, 2008 | 01:02 PM
Fresh'86's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">
For a street engine, how do you use a filter with the way that's set up?</TD></TR></TABLE>
You can't use any filter, fuel shoots into the horn and that's how it runs.
Old Aug 28, 2008 | 03:23 PM
alterdcreations's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (Fresh'86)
if you have enough space you could fab up a crazy air box
Old Aug 28, 2008 | 03:46 PM
IntegraType-R's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (alterdcreations)
69mm wtf..
why not just go 70mm
Old Aug 29, 2008 | 04:59 AM
ronstrong's Avatar
Default Re: 69mm TB vs ITB - Which would you go for? (IntegraType-R)
Hi i want to ask for some tuning info
i am going with a new setup now a B18C5 Jdm type R engine with Itb's
i want to ask for some tuning tips
i someone can make me smart about this i will appreciate it very much
Old Aug 29, 2008 | 08:06 AM
Bisimoto's Avatar
I do not use filters.
Tippyman
46
Oct 31, 2005 05:34 PM
555R
Feb 28, 2005 06:32 PM
ActiveAero
Apr 2, 2004 07:28 AM
