Wat to do about oil?
Ok, so anyway my hatch burns a little oil so i put the lucas stop leak in and it say's for every 4 qts of oil add one quart of the stop leak.....so thats what i do but it is showing it to be a little bit past the 2nd dot on the dipstick meaning its overfilled...what should I do?
it will burn out i believe it has before...bout 200 mles of driving it will drop some when the stop leak kicks in.....even if something does happen i figure o well its only a d15b1 engine and it would give me reason to upgrade
Overfilling the crackcase causes pressure problems that can blow out your rings and cause severe oil blowby/burning. Not to mention forcing oil leaks in the pan gasket....
There is a reason that there are marks on the dipstick.
