Lighting HID/Xenon kits, Retrofits and Associated Topics
CAR DIES.WEIRD LIGHTING PROBLEM!!
Old Aug 17, 2008 | 03:04 AM
da9blk1's Avatar
Default CAR DIES.WEIRD LIGHTING PROBLEM!!
ok so tonight i was driving my car and i get down the hill and shut my car off. get out. for a bit and then get back in. my car was making a weird clicking noise (main relaY) really fast tick tick tick tick.(y is that ticking)
then my radio, headlights, cornerlights stop working, windows and START UP dont happen, like theres no juice..
so i jump start it and drive it home
well when almost home, my car lights (cluster get really dim as do my headlights.
i flick on my turn signal but there not there.(cluster or outside)
i try and flick on my highbeams and my car slows down? wtf?
WELL EVENTUALLY while driving the car shuts off and dies. and does not want to start.
Old Aug 17, 2008 | 12:06 PM
da9blk1's Avatar
Default Re: CAR DIES.WEIRD LIGHTING PROBLEM!! (da9blk1)
help!!!!!!!!
Old Aug 17, 2008 | 05:58 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Sounds like your alternator is taking a dump and the car is running off the battery. Check the alternator belt and output.
Old Aug 17, 2008 | 09:12 PM
Relic1's Avatar
battery connections, grounds, alternator, faulty fuses, harness problem, main relay issue, ECU issue.
pretty much in that order.
Old Aug 18, 2008 | 05:35 PM
kisses's Avatar
Yup, check your batteries or just a quick gas up will work. Your wirings too. That's a lot of electricity and starting up problem. Was your ride still a good deal until now? When did you got your last maintenance or automotive check?
____________________
Autopartswarehouse is a must!
Old Aug 19, 2008 | 01:52 AM
da9blk1's Avatar
Default Re: CAR DIES.WEIRD LIGHTING PROBLEM!! (kisses)
i belive it was the power wire was loose at the battery. it just slid out when i turned the terminal connector...i will update after a long drive with the headlights on
thanks everyone
hey relic
Old Aug 19, 2008 | 07:23 AM
Relic1's Avatar
good news or are you still walking home?
you can check it without getting yourself potentially stranded. A simple volt meter will tell you what's going on in a few seconds. (you don't need anything expensive, the $10-15 radio shack versions work great)
car idling
>13.8V = regulator dead, replace immediately
13.2-13.8V = alternator good
12.8-13.2V = alternator weak
<12.8 = alternator not working
note: these are off the top of my head voltages, not to be used as a rule.
da9blk1
Sep 15, 2008 09:43 AM
sanimalp
28
Jul 28, 2008 02:35 PM
5spdIntegra
Oct 22, 2007 06:17 PM
kyorishin
Nov 9, 2006 02:54 PM
variablevalve
Oct 8, 2004 10:26 AM
