Transmission Help
Hey guys umm i bought a 92 integra from a friend recently and he put a vtec engine from probably a 96 integra and wat ive noticed is the car shifts perfect all the way into 5th but get real high rpms at 60mph at probably more than 4000rpm should i get a transmission from the 96 vtec because the car is a 92 or the transmission is right but needs a clutch kit appreciate the help guys!!
well lets see umm its not aftermarket but the rpm gauge in the dash isnt working could this be connected with me getting high r's while im just cruising in 5th?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitericer85 »</TD></TR><TR><TD CLASS="quote"> should i get a transmission from the 96 vtec because the car is a 92 or the transmission is right but needs a clutch kit appreciate the help guys!!</TD></TR></TABLE> no. it wont work without some sort of conversion vit. 96 tranny is hydro and 92 is cable. if anything get a b16 cable tranny. does it rev fast? you might already have one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitericer85 »</TD></TR><TR><TD CLASS="quote">the car shifts perfect all the way into 5th but get real high rpms at 60mph at probably more than 4000rpm</TD></TR></TABLE>
If the tach/speedo is working correctly and you are running 4K at 60mph, chances are you have a 92-93 GSR cable tranny or more probable a JDM B16A cable tranny. The stock LS tranny would be pushing around 4K at 80mph.
