Suspension & Brakes Theory, alignment, spring rates....
Lowering my honda fit gonna cause camber issues?
Old Aug 16, 2008 | 03:27 PM
2fast4ahonda's Avatar
Default Lowering my honda fit gonna cause camber issues?
Just bought a 2008 honda fit sport...I want to lower it 1.6 1.8" drops....will i have to get an alignment or camber kit? I dropped my Talon(2fast4ahonda) and it was a headache...$75 camber bushings....and 3 hours of torching/labor/hassle.....hundreds of dollars later....it was done.....i had to go 3 different shops to get someone to align my car cause it was lowered.....if it will be a hassle.....i dont want to deal with it.........oh yeh are the skunk springs really that much better than cheap ebay springs? And are my stock struts gonna blow out in 3 months? I have tein springs and kybs on my talon....handles great .....rides like crap......i dont want my fit to ride like crap(bumpy)
Got some 16" hyundai wheels that i am gonna throw on the fit...hopefully i wont need spacers..got em for $200 with 1000 miles on the kuhmos
Modified by 2fast4ahonda at 4:35 PM 8/16/2008
Old Aug 16, 2008 | 05:20 PM
batallic's Avatar
Default Re: Lowering my honda fit gonna cause camber issues? (2fast4ahonda)
just get an alignment, im dropped 2.5 inches and didnt need camber kits
Old Aug 16, 2008 | 05:24 PM
Default Re: Lowering my honda fit gonna cause camber issues? (batallic)
Did you drop a fit tho? or civic, accord, other models? Hopefully you have the same car. I didnt see alot of replies on this topic. You thing they really hate my screen name?
Old Aug 17, 2008 | 05:48 AM
batallic's Avatar
i have a 93 ex, even search and many will say u dont need camber for that little of a drop
Old Aug 17, 2008 | 12:32 PM
E-Money's Avatar
dont drop it over 2 inches. get a alignment right away if you value your rubber. buy some decent rubber. dont buy junk2 springs.
Old Aug 17, 2008 | 01:52 PM
So i should buy tein or eibach springs then?
How long will the install take my mechanic?
Old Aug 17, 2008 | 04:02 PM
E-Money's Avatar
i went with koni and eibach pros
Old Aug 17, 2008 | 08:04 PM
brzrkr's Avatar
I say get a camber kit.
Old Aug 19, 2008 | 10:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (brzrkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brzrkr &raquo;</TD></TR><TR><TD CLASS="quote">I say get a camber kit.</TD></TR></TABLE>
And I say that's a waste of money. More money on parts, more time and money to align it, much more hassle and headache, possibility of slipping, etc.
I have had as much as -2.8 degrees of camber on my car, with no camber kit, and minimal tire wear issues. Toe is what does the most damage to tires. Toe and camber both change when the car is lowered, and when you get a camber kit and have it aligned, toe is also corrected, which fixes the tire wear. But really only an alignment to fix the toe is needed.
It will not be any more hassle to align if they only adjust the toe. The only hassle will be if the car is too low and has trouble getting up on the rack.
Now I'm not sure but I think the Fit has Mac struts up front, like the newer Civics and RSX's. If that's the case, you will see very little, if any, negative camber after lowering. The rear may take on some negative camber, but again, and alignment to fix the toe is really all that's needed.
SubwayH23
Aug 23, 2018 03:27 AM
rycrkt
Suspension & Brakes
Mar 11, 2011 03:47 PM
gsr336
Jul 12, 2006 09:15 PM
shanedapain
May 6, 2004 11:14 AM
SiRocket02
Dec 28, 2003 09:06 AM
