HELP. Rear disc 88 Si question.
Old Aug 16, 2008 | 12:14 PM
schueytenten's Avatar
Default HELP. Rear disc 88 Si question.
Here is the deal. I posted about a year ago after I did a rear disc swap on my 88 Si about uneven pad wear. Basically after I swapped the rear trailing, the pads completely wore on the top (or maybe it was the bottom) and the bottom part (or maybe it was the top) was still pretty new. They wore to the point of ruining the rotors.
I thought it might have been bad calipers on the swap I purchased, so just last month I put on new pads, new rotors, and new calipers, and I seem to have the same problem happening again.
Any idea what could be going on creating the uneven wear?
Old Aug 16, 2008 | 01:14 PM
FernEF's Avatar
Default Re: HELP. Rear disc 88 Si question. (schueytenten)
hm... check out your e-brake cables
Old Aug 16, 2008 | 03:28 PM
almost_stock_civic's Avatar
Default Re: HELP. Rear disc 88 Si question. (FernEF)
make sure the calipers slide freely in the grooves on the brackets (where the shiny metal clips are). if the top and bottom can't move at the same time, one end of the pad will clamp down and the other will hang and not wear evenly.
Old Aug 16, 2008 | 03:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FernEF &raquo;</TD></TR><TR><TD CLASS="quote">hm... check out your e-brake cables</TD></TR></TABLE>
Thats what I was thinking all along. What could the deal be? I am guessing that maybe it is adjusted too tight and that could be causing the problem.
thanks for the reply.
Old Aug 16, 2008 | 03:51 PM
I am thinking it has to be with the ebrake because everything else has been replaced and that is the only part left from the original swap.
Looks like I have something to do tomorrow now besides
Old Aug 16, 2008 | 11:05 PM
Tyson's Avatar
you get any vibrations from back there?
wonder if the run out on the rotor is ok.
Old Aug 17, 2008 | 04:28 PM
Default Re: HELP. Rear disc 88 Si question. (Tyson)
Basically it feels like the rotor is really warped. When I slowly brake for like a light, you can feel the pad grab and then it feels like it's releasing quickly and grabbing again. No vibration at all. Just feels a little off.
Old Aug 17, 2008 | 04:29 PM
dr_latino999's Avatar
How are the rear wheel bearings?
Old Aug 18, 2008 | 12:16 PM
Default Re: HELP. Rear disc 88 Si question. (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">How are the rear wheel bearings?</TD></TR></TABLE>
That I don't know about. How do I check those? Do you do it the same way as the fronts? Lift the rear off the ground and give the wheel a tug to check for movement?
Old Aug 29, 2008 | 01:20 PM
anyone. help on how to check if the rear bearings are ok?
Old Aug 29, 2008 | 01:35 PM
Ermil's Avatar
Lift the rear end, spin the wheels, listen for noise, check for play.
I did my rear disc swap recently and have no issues. I have brand new everything so it works out pretty well. Good luck.
mynameisChris
Aug 15, 2009 06:57 AM
mugencivic94
Aug 30, 2007 06:02 PM
sircrxracer
10
Jul 24, 2004 01:21 AM
hondaeg95
33
Feb 24, 2004 07:03 PM
