Suspension & Brakes Theory, alignment, spring rates....
Eibach bumpstop question
Old Aug 15, 2008 | 04:42 PM
shibbywhitedude's Avatar
Default Eibach bumpstop question
I posted awhile back about my 98 Accord squeaking after installing the Eibach Pro Kit (springs and struts). I took it to several shops to find out what it was and one finally got it right. It's the strut bumpstop. My bumpstops are in constant "bottom out" mode lol. He jacked the car up and showed me. When he let it down you could clearly see the car kept going until it was resting on the bumpstops of the strut. Does anyone know if it is supposed to sit on them normally? That's where the squeaking is coming from. The shaft of the strut moving through the bumpstop. It's really annoying. Any help would be more than great! Thanks all!
Old Aug 16, 2008 | 10:14 AM
Default Re: Eibach bumpstop question (shibbywhitedude)
Anybody?
Old Aug 21, 2008 | 10:50 AM
bump
Old Aug 21, 2008 | 11:47 AM
cpl rampage's Avatar
Default Re: (shibbywhitedude)
no its not supposed to sit on the bump stops, do you have lowering springs or cut/heated springs?
Old Aug 21, 2008 | 06:04 PM
GReatEDDY's Avatar
call Eibach tech support.
Old Aug 23, 2008 | 10:34 AM
I called them and they told me that it is supposed to be like that and that the bumpstops have enough give so as to not ride really rough. And no I do not have heated springs, I have all Eibach junk.
Old Aug 23, 2008 | 12:26 PM
forced00si's Avatar
cut the bumpstops. or take them out and put in some polly ones.
Hondatypr636
May 10, 2014 12:31 PM
hillbillycivic
Suspension & Brakes
Jul 17, 2012 07:48 AM
gosu08
Oct 14, 2006 06:15 AM
ac04
Aug 17, 2004 12:46 AM
kent
12
Apr 2, 2003 10:46 PM
