will a cold air intake on a stocker make much of a difference???
Old Aug 15, 2008 | 02:04 PM
saddler263's Avatar
Default will a cold air intake on a stocker make much of a difference???
98civic ex all stock is it worth the money without the exhaust
Old Aug 15, 2008 | 02:06 PM
The Collin's Avatar
Default Re: will a cold air intake on a stocker make much of a difference??? (saddler263)
It will sound different. There's your main difference.
Old Aug 15, 2008 | 02:56 PM
beevo.'s Avatar
Default Re: will a cold air intake on a stocker make much of a difference??? (99_hb_on_air)
^ what he said. You would be just as well off with a warm air...plus, you wont have to worry about hydrolocking your motor.
Old Aug 16, 2008 | 09:29 AM
EKstacy's Avatar
Default Re: will a cold air intake on a stocker make much of a difference??? (beevo.)
just drop a K&N filter into your airbox and youll notice about the same.
Old Aug 16, 2008 | 09:56 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_hb_on_air &raquo;</TD></TR><TR><TD CLASS="quote">It will sound different. There's your main difference. </TD></TR></TABLE>
It'll only sound different if he has a stock exhaust - because the pressure won't be balanced.
If he has an aftermarket exhaust, chances are it's wider, the pressure will be more balanced - you won't hear it again.
EDIT:
@ OP:
You'll think you notice a difference because it'll be a bit louder without the resonator - but you won't actually have a difference.
As the one guy said, throw a K&N drop in filter in there (goes in your stock air box) and call it a day. Thats as much gain as you'll get - and it's not even enough to feel in ur *** dyno - just in ur mind because you know it's there.
I find it very convenient to use a "short ram" intake though - because it's very easy to remove (2 screws just need to be loosened) to have access to that whole side of the engine. Though that's all it does.
Old Aug 16, 2008 | 10:16 AM
labtec2's Avatar
no, it will sound a little deeper buuuuuuut thats about it.
Old Aug 16, 2008 | 10:37 AM
yoontim23's Avatar
No, but it's a start and you'll be able to hear it.
Old Aug 16, 2008 | 12:19 PM
The Collin's Avatar
Default Re: will a cold air intake on a stocker make much of a difference??? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly why I said what I did. He asked if it would make a difference on an all stock Civic. My answer fits. But, you're right about both parts
raverx3m
Jun 20, 2013 09:21 PM
asergioc
36
Aug 21, 2007 11:43 PM
Bourdoncivic
Honda Civic (2001 - 2005)
Aug 9, 2007 02:17 PM
2007SiNister
Honda Civic (2006 - 2015)
Dec 18, 2006 11:59 AM
jtchinoy
19
Apr 19, 2006 01:58 PM
