head work
i didnt think this should go in the cam section of the faq because it really doeset fall under that category, but here goes..
when i upgrade my cam (to a crower stage 2) and look to get new valves, springs, and retainers, it says do not use titanium retainers with a daily driver, why? also it says not to use the cam with oversized valves, why? shouldnt i be okay with a valve thats .050 over with the cam? or is there an issue that i dont know about. head will be going on a 00 base h22a4, port and polish will be done and crower cams with crower springs retainers and valves. aem cam gears, s2 IM, 68mm tb, aem cai etc
thanks in advance
thanks in advance
Crower cams haven't been especially impressive, at least with the H22's. Nothing seems to out do the Skunk2 Pro series cams. If they're over your budget, save for them.
Titanium retainers will be a wear item.
Search Skunk2 Pro series and Crower dyno's. The pattern of results will be pretty obvious from the beginning. Buying parts because you heard they're good is a bad way to go.
Supertech makes good valvetrain.
allright, yeah im on supertech's site now, im seeing ferrera aluminum/magnesium retainers on importperformanceparts.com, but nothing other than that and the titanium ones.
Supertech, Ferrea, Rocket are all good options. Contact one of the sponsors (search the Sponsor forum) for Supertech and Ferrea, and you can contact user Aquafina for Rocket.
B18B1-Crx
Apr 2, 2010 06:08 AM
Nors
Apr 7, 2007 05:39 AM
ChickenH
Mar 4, 2007 08:53 AM
