taking middle bolt off steering wheel, HELP
Old Aug 15, 2008 | 10:00 AM
eesuh's Avatar
Default taking middle bolt off steering wheel, HELP
ok so im trying to put the nrg hub and QR set up on my car but that dam middle bolt in the middle of the steering wheel wont come off! does anyone have any solutions on how to take it out?? let me know thanks!!
Old Aug 15, 2008 | 10:12 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: taking middle bolt off steering wheel, HELP (eesuh)
if it.s havin problems comin off spray pb blaster on it. .shouldnt be to hard. .19mm socket w an extension. .hold the steering wheel w one hand n use otha on the ratchet obviously.
Old Aug 15, 2008 | 10:14 AM
eesuh's Avatar
Default Re: taking middle bolt off steering wheel, HELP (Egezzy)
alright ill try and use a spray, if not im coming back, thanks for now!
Old Aug 15, 2008 | 01:23 PM
PBzAllan's Avatar
thats what i did but with a long breaker bar also
Old Aug 15, 2008 | 01:49 PM
superfast666's Avatar
Default Re: taking middle bolt off steering wheel, HELP (PBzAllan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egezzy &raquo;</TD></TR><TR><TD CLASS="quote">if it.s havin problems comin off spray pb blaster on it. .shouldnt be to hard. .19mm socket w an extension. .hold the steering wheel w one hand n use otha on the ratchet obviously.</TD></TR></TABLE>
why would you have too hold the steering wheel they have a lock on the column
Old Aug 15, 2008 | 02:17 PM
Relic1's Avatar
Default Re: taking middle bolt off steering wheel, HELP (superfast666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">
why would you have too hold the steering wheel they have a lock on the column </TD></TR></TABLE>
cause the latch housing is cast aluminum, it's breaks fairly easy when you have a breaker bar attached and pushing hard. It's also a pain to replace.
It will take some abuse, bet get roudy with it and you'll be pulling apart the rest of the column and trying to get out security bolts.
impact wrench is best.
Old Aug 15, 2008 | 02:36 PM
00ekcoupe's Avatar
Default Re: taking middle bolt off steering wheel, HELP (Relic1)
Impact wrench would be best and easiest. Just put some muscle into it, it should come off.
ohsojdmdc
Nov 10, 2009 06:33 AM
SHG_Claudio
15
Dec 31, 2008 12:37 PM
dc2long
Aug 31, 2007 01:57 PM
civicDX2178
Jul 5, 2006 01:17 PM
Bandit74
15
Sep 17, 2004 09:36 PM
