Cat Converter
Old Aug 15, 2008 | 08:35 AM
KDL323's Avatar
Default Cat Converter
I have a 1996 Civic Dx. My car has a straight pipe and my smog is coming up.
I still have the stock DX headers. but i dont have a cat under the car. Will a universal magnaflow cat pass me. Are Ex/SI cats interchangeable with Dx?
Old Aug 15, 2008 | 11:45 AM
DAP97SI's Avatar
Default Re: Cat Converter (KDL323)
If I am not mistaking a DX doesn't have the cat under the car, it is located with the manifold, so it is one component.
Old Aug 15, 2008 | 12:09 PM
B16AGUY's Avatar
Default Re: Cat Converter (DAP97SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAP97SI &raquo;</TD></TR><TR><TD CLASS="quote">If I am not mistaking a DX doesn't have the cat under the car, it is located with the manifold, so it is one component. </TD></TR></TABLE>
That is 100% correct, the ex. manifold and cat on the 96 DX are attached as a single unit which is followed by the flex pipe. So if you still have the stock mani on there, you should have a cat. It's easy to tell... Pop the hood & look straight down at the front of your engine. You should see the ribbed cat in the front right below the mani. It's about 2-3 inches below the O2 sensor.
KDL323
Aug 12, 2008 04:48 AM
joemoe
Honda Civic (2001 - 2005)
Dec 26, 2007 06:29 PM
ttran
Jul 8, 2004 09:59 AM
igo4bmx
Jul 31, 2003 06:03 AM
94dxt
Apr 7, 2003 04:34 PM
